Go to Post IMO, everyone should experience at least one Battlecry. - Dan Petrovic [more]
Unread 07-01-2015, 17:05
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: 2015 Control System Frying Victors
Originally Posted by icecube45 View Post
Hello!
When the robot is disabled, the robot continues to spin in a circle,
You have a short, either at the motor controller or the drivetrain motor itself (case short). I would highly suggest checking your wiring again.
We have used over 4 different RoboRio's since 2013 (Alpha and Beta testing) and have not had a single issue with any of them frying motor controllers on a correctly wired system.
Hope that helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 07-01-2015, 18:31
icecube45's Avatar
icecube45 icecube45 is offline
Drive|Programming|Captain
FRC #0114 (Eaglestrike)
Team Role: Driver
icecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the rough
Hope that helps,
Kevin
I believe the victor is frying in such a way that it shorts, being as the only motor moving at the time of disable, is the fried victor.
Unread 07-01-2015, 18:58
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
I have had no roboRIO experience yet, but, the cRIO control system outputs 5v through the red cable in the PWM by default(presumably for the use of speedcontrollers), but page 13 of the roboRIO manual says it outputs 6v there always.
However, if this was a real problem, it would have gotten caught in beta testing, and it wasn't. It is probably not the issue. As to what is, I couldn't tell you. Its definitely shorting with that kind of voltage drop.
Link to roboRIO manual https://decibel.ni.com/content/docs/DOC-30419
Unread 07-01-2015, 19:15
The Digital Sidecar output 6V on the center pin when the servo jumper was installed. It was disconnected when the servo jumper was not installed. The roboRIO does output 6v all the time on the center pin. However, all FRC legal speed controllers have the center pin disconnected, so it doesn't matter what the roboRIO outputs.
Unread 07-01-2015, 19:58
icecube45's Avatar
Team Role: Driver
So, turns out we were just unlucky...
We put on a fourth victor, and after using combinations of the pdp and pdb, we trusted it enough to hook everything up.
It worked fine..
I guess all we've learned from this is:
it's the mechanical team's fault.
Unread 07-01-2015, 20:06
AKA: Sparks
Thanks! I didn't know that, and was wondering how that worked.
Unread 07-01-2015, 22:02
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
It worked fine..
So did you find out what the actual problem was though, so you can avoid it in the future? (Or maybe help any other teams reading who might have the same problem?)
I'm assuming it was inverted polarity?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 07-01-2015, 22:10
John Retkowski's Avatar
John Retkowski John Retkowski is offline
Team 316 mentor
AKA: Wyatt. Call me Wyatt.
FRC #0316 (LuNaTeCs)
John Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of light
It was obviously all the code weighing down on the victor fan causing the victor to over heat and get a nice crispy golden brown color all over.
It's always the programmers fault.
2015 MAR District Championship #1 seed Winners (w 225 & 203)
2015 Upper Darby District #2 Seed Finalist(w 272 & 5420)
2015 NE Pioneer Valley District #3 Seed Finalists (w 61 & 663)
2014 Lenape Seneca District Champions (w 3929 & 2559)
2014 Springside Chestnut Hill District Champions (w 225 & 1495)
2013 Lenape Seneca District Champions
2013 Springside Chestnut Hill Finalists
Unread 07-01-2015, 23:09
icecube45's Avatar
Team Role: Driver
It was not inverted polarity...
We just had 3 unlucky victors in a row
(see: mechanical people stupidly drilling over electronics)
Unread 07-01-2015, 23:50
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
We're overweight! Quick, delete some code!
It's always the co-captain's fault.
