Go to Post While science and technology can solve difficult problems, it is people and interaction that make it all work. - DonRotolo [more]
Unread 07-01-2015, 20:10
kingsley.osei kingsley.osei is offline
FRC #4684
kingsley.osei is an unknown quantity at this point
Parameter of the Robot base
How big can the parameter of the robot be?
And how far outside of the frame can the arms extend.
And can you start a match with the arms already extended?
Unread 07-01-2015, 20:12
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Re: Parameter of the Robot base
There is no rule that dictates how large any extension can be or how large your robot may be on the field excluding a height limit of 78 inches tall. That being said, while in transport, there is a specified volume that the robot must fit within as per R3:
The ROBOT must satisfy the following size constraints:
A. during a MATCH, the ROBOT height may not exceed 78 in.
B. the ROBOT must be able to be arranged into a TRANSPORT CONFIGURATION with dimensions which do not exceed 28
in. wide, 42 in. long, and 78 in. tall.
You have up to one minute to set up your robot on the field before a match. All of these points should be considered when designing your robot, and specifically the extensions beyond the frame perimeter and how the robot will fit into the transport configuration.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 07-01-2015, 20:22
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
As per R3:
"The ROBOT must be able to be arranged into a TRANSPORT CONFIGURATION with dimensions which do not exceed 28 in wide, 42 in long, and 78 in tall"
This means that there are no specific rules for the frame dimensions, but it is unlikely that you will be able to reduce the size of your frame in under a minute so the frame limitations would likely be 28 in by 48 in. (Although technically, you might be able to tilt the robot on it's side for transportation. It depends on if the coordinate system of the "28 in wide, 42 in long, and 78 in tall" is relative to the floor or to the robot's orientation. I would strongly encourage you to check in the Q &A forum before running with this idea)
There are no rules during the competition that say how far away from the frame area that a mechanism can extend in the match. Once again, I would be sure though that whatever mechanisms you build will be able to fold up to fit into the
Unread 07-01-2015, 20:42
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Don't want to be a jerk but please
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 07-01-2015, 21:54
FRC #4684
THanks To you all for the help, We built the robot in a square using 31in wide bu 32 inch long. Our drive train uses four motors, three wheels on each side. We were thinking about going with the OMNIWHEELS. What is special about them?
Unread 07-01-2015, 22:02
theCADguy's Avatar
Happy Birthday! theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Omni wheels have a set of rollers perpendicular to the front of the wheel. This allows them to have sideways and forward movement, that doesn't require turning. You can put the wheels in an orientation like this:
The wheel(s) in the center can drive the robot sideways, because the rollers on the side wheel allow perpendicular movement. Considering that your center of mass is directly over the center wheels, this style of drive (referred to as slide or H - drive) is capable of excellent omni directional maneuvering.
Hold up a minute. If your robot is 31" x 32", you will need to have some method of losing 3" or so for transport.
As far as omniwheels, they allow very easy sideways movement. You REALLY want traction wheels of some form, though omniwheels may be useful on the corners IFF the center wheel is not dropped.
Unread 07-01-2015, 22:12
mackenzieg's Avatar
mackenzieg mackenzieg is offline
AKA: Mackenzie Glaser
FRC #1261 (Robo Lions)
mackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of light
Omni wheels are good for extra maneuverability, but as Eric said, you do want traction wheels (at least the center wheels) on your robot.
Simbotics has a really good resource on a lot of different types of drivetrains, I'd suggest taking a look here: http://www.simbotics.org/resources/m...rain-selection
Mackenzie Glaser
Team 1261
Unread 07-01-2015, 23:03
philso philso is offline
FRC #2587
The learning curve for FRC is steep and long. It may be of benefit for your team to find a more established team in your area who can meet with your team. A few hours of in-person meetings can bring you up to speed with the basics much faster than asking many basic questions here. They can also identify holes in your knowledge better than the people posting here. You can then come back and ask more specific questions.
Unread 08-01-2015, 15:53
cusack99 cusack99 is offline
None #5256
cusack99 is an unknown quantity at this point
So we made the standard long chassis and are fully up and running. We have our mechanism designed but with our chassis 32" long do we have to have our arms upright at the beginning in transport to stay under 42"???
Unread 08-01-2015, 16:23
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Yes. There is no concept of a frame perimeter this year, only that the entire robot fits within that bounding box for the transport configuration. Note that you can carry the robot onto the field and unfold the arms before the start of the match.
Unread 08-01-2015, 16:29
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
The other restriction that many seem to miss is G7-C - that the starting configuration can not be in either the AUTOZONE, nor the LANDFILL ZONE. There are already questions in the Q&A if the space above the zones are included in the restriction.
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Or, if you want to be slick, have the robot unfold its own arms during autonomous.
Unread 08-01-2015, 16:30
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Yeah, before you do anything else, you guys need to fix this or you'll be in for quite a surprise at competition.
Unless you are going to get really complicated, one dimension of your frame has to be under 28".
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 08-01-2015, 16:40
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Actually, you needn't get overly complicated to have your frame length and width >28".
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
