Go to Post You don't always get what you pay for, but you hardly ever get what you don't pay for. - MrForbes [more]
Unread 07-01-2015, 21:54
kingsley.osei kingsley.osei is offline
FRC #4684
kingsley.osei is an unknown quantity at this point
Re: Parameter of the Robot base
THanks To you all for the help, We built the robot in a square using 31in wide bu 32 inch long. Our drive train uses four motors, three wheels on each side. We were thinking about going with the OMNIWHEELS. What is special about them?
Unread 07-01-2015, 22:02
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Omni wheels have a set of rollers perpendicular to the front of the wheel. This allows them to have sideways and forward movement, that doesn't require turning. You can put the wheels in an orientation like this:
The wheel(s) in the center can drive the robot sideways, because the rollers on the side wheel allow perpendicular movement. Considering that your center of mass is directly over the center wheels, this style of drive (referred to as slide or H - drive) is capable of excellent omni directional maneuvering.
Happy Birthday! EricH EricH is offline
Hold up a minute. If your robot is 31" x 32", you will need to have some method of losing 3" or so for transport.
As far as omniwheels, they allow very easy sideways movement. You REALLY want traction wheels of some form, though omniwheels may be useful on the corners IFF the center wheel is not dropped.
Unread 08-01-2015, 16:30
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Yeah, before you do anything else, you guys need to fix this or you'll be in for quite a surprise at competition.
Unless you are going to get really complicated, one dimension of your frame has to be under 28".
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 08-01-2015, 16:40
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Actually, you needn't get overly complicated to have your frame length and width >28".
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 08-01-2015, 17:22
dellagd's Avatar
AKA: Griffin D
I'm assuming they'll want the height of their robot to be over 42" tall, which I guess is not totally necessary. Regardless, I don't see why they would be unable to trim three inches. Having to severely limit your robot's transport configuration height probably isn't worth it over something like this that could be remedied and would allow much mroe flexibility later in the build process. I mean, its only what, day 6?
Unread 08-01-2015, 18:03
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Not that big.------->See the video.
https://www.youtube.com/watch?v=FeVghhvw9dQ
And...Not that big either...
https://www.youtube.com/watch?v=vAiwLRGsNrE
Note: Please read ALL of the 2015 FRC rules before designing & building a Robot.
We want you to be able to play the game when arriving at the competitions, instead of having to help you rebuild it there (If we can all avoid it, OK?).
Please see The Rules, Robot Section; R3 & R4 for Transport Size & Wt. constraints. There are other rules that apply this year also (such as there is no on the field width X length constraint as long as it fits within the transport size...pits to the field, through doors, gates, etc....though there is a Max. height limit, both on, or off the field, and you must be able to setup and break down reasonably on the field within 1 minute or less, and everything must fit into that transport box size limitation for transport throughout the venue). So reading all the rules is very important...Stop building, start reading OK?
Unread 07-01-2015, 22:12
mackenzieg's Avatar
mackenzieg mackenzieg is offline
AKA: Mackenzie Glaser
FRC #1261 (Robo Lions)
mackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of light
Omni wheels are good for extra maneuverability, but as Eric said, you do want traction wheels (at least the center wheels) on your robot.
Simbotics has a really good resource on a lot of different types of drivetrains, I'd suggest taking a look here: http://www.simbotics.org/resources/m...rain-selection
Mackenzie Glaser
Team 1261
Unread 07-01-2015, 23:03
philso philso is offline
FRC #2587
The learning curve for FRC is steep and long. It may be of benefit for your team to find a more established team in your area who can meet with your team. A few hours of in-person meetings can bring you up to speed with the basics much faster than asking many basic questions here. They can also identify holes in your knowledge better than the people posting here. You can then come back and ask more specific questions.
Unread 08-01-2015, 15:53
cusack99 cusack99 is offline
None #5256
cusack99 is an unknown quantity at this point
So we made the standard long chassis and are fully up and running. We have our mechanism designed but with our chassis 32" long do we have to have our arms upright at the beginning in transport to stay under 42"???
Unread 08-01-2015, 16:23
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Yes. There is no concept of a frame perimeter this year, only that the entire robot fits within that bounding box for the transport configuration. Note that you can carry the robot onto the field and unfold the arms before the start of the match.
Unread 08-01-2015, 16:29
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
The other restriction that many seem to miss is G7-C - that the starting configuration can not be in either the AUTOZONE, nor the LANDFILL ZONE. There are already questions in the Q&A if the space above the zones are included in the restriction.
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Or, if you want to be slick, have the robot unfold its own arms during autonomous.
