Go to Post Guys guys, what a coincidence! I INFACT <3 ROBOTS TOO! - Kusha [more]
Unread 07-01-2015, 20:03
ssultana10 ssultana10 is offline
FRC #2291
ssultana10 is an unknown quantity at this point
Scissor Lifter?
Hey all, I was just wondering about experiences that other teams have had regarding scissor lifts??
All comments welcome, I'm just trying to explore all of the possibilities!!
Unread 07-01-2015, 20:18
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Scissor Lifter?
Put it this way, I doubt anyone has ever built a Second scissor lift
Seriously though they rarely work very well, they all seem to wobble a lot when they get very high.
Unread 07-01-2015, 20:27
Re: Scissor Lifter?
No experience, except that I spend a lot of time on man-rated industrial scissor lifts.
If stability is important, scissor lifts of more than one stage should be rated as do not use. I walk from one end of a lift to the other, it sways a bit.
If simplicity is important, scissor lifts in general should be rated as do not use. (See: elevator system, pneumatic lift)
If you can't do much precision work... See the bold text above.
If you are seriously considering doing a scissor lift system, you should do the math. I've heard of engineers getting scared of that math. You need to account for all the stages, the stability, and the precision needed. It's not easy.
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: Scissor Lifter?
Very well put. Scissor lifts are just way more complex than they need to be for FRC application. Most of the Ri3D teams chose to use elevators for a reason. They are simple, can be light weight, and effective.
Unread 07-01-2015, 21:31
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Re: Scissor Lifter?
No. Absolutely not. But I am sure we will see a few teams using them.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 07-01-2015, 21:42
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Re: Scissor Lifter?
We used a scissor lift once on 842 back in Ultimate Ascent. We used it to bring Frisbee to our shooting mechanism because we somehow forgot about gravity. I don't think you could pay us enough to make another scissor lift. Despite it being very small and simple, it was very inconsistent, never landed right, jammed regularly and overall wasted dozens of hours due to having to adjust it. Even if you can get one working quickly compared to an elevator, the time spent fixing and adjusting it is not worth it at all.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 07-01-2015, 21:48
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Scissor Lifter?
At the start of each season, I remind the team of our two absolute rules (born from very bad experiences):
1. No mecanums (yes, even this year)
2. No scissor lifts
My FTC team came to me with a design that included a scissor lift. I asked if that was the best design the could come up with. They said it was. I said you need to try harder! The have a much better design now!
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 07-01-2015, 21:52
ShinyShips's Avatar
ShinyShips ShinyShips is offline
Former Operator and Captain
AKA: Andy
FRC #3314 (Mechanical Mustangs)
ShinyShips is on a distinguished road
Re: Scissor Lifter?
There are only two rules when designing on our team:
  1. No turntables
  2. No scissorlifts
I haven't had any experience with scissorlifts, but our mentors must have a really good reason for not wanting to ever have one.
Unread 07-01-2015, 22:01
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Scissor Lifter?
The Digital Goats have two rules.
#1 No casters.
#2 No scissor lifts.
Unread 07-01-2015, 22:14
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Scissor Lifter?
I have one rule that applies to FTC more than FRC and it is as follows:
Unless you have to raise an object more than 20ft in the air. A scissor lift is not the answer.
(Bascially unless we play a game like 2011 (bowled over) again you shouldn't need to use a scissor lift.)
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 07-01-2015, 22:21
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Scissor Lifter?
(Bascially unless we play a game like 2010 (bowled over) again you shouldn't need to use a scissor lift.)
Bowled Over was 2011-12. I'll agree that it was probably the only time I've ever seen a scissor lift that was actually effective. Seeing teams shoot those crate 20-30 feet up with elastic powered scissor lifts was both really cool and really scary.
If you want to be successful this year at competitions, a scissor lift is almost certainly not the way to go. Build a nice elevator or something. You only actually need one stage this year.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 07-01-2015, 22:23
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Scissor Lifter?
Out of curiostity, what's if it's single stage? I.E. Two bars that cross with a joint in the middle.
Assume that it's milled accurately and not made on a drill press.
Unread 07-01-2015, 22:35
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: Scissor Lifter?
We used a scissor lift in 2013 to score the colored discs while our robot was on the pyramid. We needed a compact mechanism to lift a few frisbees a few feet, and I thought it worked great for us.
Obviously this is very different than lifting totes;however, I think they can work well in specific applications, and to automatically rule them out is a mistake.
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 08-01-2015, 01:26
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Scissor Lifter?
  1. No turntables
  2. No scissorlifts
Ours are:
  1. No Tank Treads
  2. No Scissorlifts
We did both in our first year and haven't done either since.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 08-01-2015, 02:40
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Re: Scissor Lifter?
#1 No casters.
I understand why casters and agree.
but whyscisser lifts
TEAM 1946-Tamra
