Go to Post Show me the mentor who has never built a bad robot and I'll show you either a new mentor, a liar, or Andy Baker. - Andrew Schreiber [more]
Unread 07-01-2015, 20:34
Hoover's Avatar
Hoover Hoover is offline
no team (None)
Hoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to all
toughbox mini mecanum
I've search the forum and I haven't found anyone who has done this. We can't be the first!
We have 4 Toughbox Mini transmissions that came with AM14U frames. They take two CIMs each, but if we put only 1 Cim on each one, can we use them for mecanum, given the gear ratios and all?
We are on a limited budget but we might be able to do it this way.
Unread 07-01-2015, 20:37
ice.berg's Avatar
ice.berg ice.berg is offline
Strategy Mentor & Drive Team Coach
AKA: Alex Bergal
ice.berg has a spectacular aura aboutice.berg has a spectacular aura about
Re: toughbox mini mecanum
Not a horrible way to go depending on your wheel size. Just make sure that you calculate out your FPS with our desired wheel size to make sure you have the output to your teams liking.
TEAM 2512 DULUTH EAST DAREDEVILS
'12-'15: Strategy and Build Mentor
'15 Hopper Division Champions and Einstein Finalists thanks 987, 2826, 4265
'15 Minnesota State Champions thanks 3130 and 4215
'15 Northern Lights Chairmans Winner and Regional Finalists & Central Illinois Regional Finalists
'10-'11:Build Captain
'13 Midwest Champion '12 North Star Champion '11 Lake Superior Champion
Website Facebook Twitter Youtube Flickr
Unread 07-01-2015, 20:42
dougwilliams's Avatar
dougwilliams dougwilliams is offline
Engineer - Controls, Electronics
FRC #2053 (TigerTronics)
dougwilliams is on a distinguished road
Not exactly what you are looking for - but we did run 4 toughbox nano's last year with mecanum's on the AM14U. We used 8 inch mecanum wheels.
It looks like the gear ratios for the nano and mini are about the same so you should be fine there, and we ran one CIM per corner like it sounds like you want to do.
We had to add some gearbox mounting holes and bearing holes in the chassis at one end, because we cut ours to a non-standard length.
We understand the limited budget
Last edited by dougwilliams : 08-01-2015 at 11:26. Reason: Fixed Mecanum spelling ;)
Unread 07-01-2015, 20:46
Hoover's Avatar
no team (None)
We are trying to find 6 inch mecanum wheels for the project as our simple test shows that 4 inch wheels are going to hang because of the length of our chassis when going over the scoring platform.
I'm the poor coder who is *just going to make this work*! The builders intend on covering up one motor mount with duct tape or something like that.
If this works I am going to endorse this method to small teams who are considering, but out of reach of, the 750 dollar upgrade kit.
Unread 07-01-2015, 21:28
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
It can definitely work. There are three ratios I would consider, 8.46:1 (included), 10.71:1, and 12.76:1. Depending on your strategy, that is your choice to make.
8.46:1
10.71:1
12.76:1
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 07-01-2015, 22:06
Mecanum Wheel's Avatar
Mecanum Wheel Mecanum Wheel is offline
It's spelled mecanum
AKA: Bengt Ilon
Mecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond repute
Originally Posted by dougwilliams View Post
Not exactly what you are looking for - but we did run 4 toughbox nano's last year with mechanums on the AM14U. We used 8 inch mechanum wheels.
Hey Doug! Just for future reference, it's spelled mecanum. It's an easy mistake to make. How did the custom bearing holes work out? Did you have to switch to chain due to the difference center to center?
Unread 07-01-2015, 22:20
evand4567's Avatar
evand4567 evand4567 is offline
AKA: Evan
FRC #2022 (Titan Robotics and Team Neutrino)
evand4567 is an unknown quantity at this point
Our team did AM14U with Touhgbox Nanos last year. We did have some difficulties with poor tolerances in andymark machining and the lack of a tapped encoder mount, which, because of the poor machining, we were unable to easily remove and tap to add the encoder. It was a mess and very difficult to assemble, although it does, in theory, work. I would not recommend doing it. I'd recommend finding some other gearboxes or make your own.
Unread 07-01-2015, 22:56
coachgallina's Avatar
coachgallina coachgallina is offline
FRC #3015 (Ranger Robotics)
coachgallina is an unknown quantity at this point
has anyone attempted to use the vexpro single reduction clamping gear box? could you get away with this set up. http://www.vexrobotics.com/vexpro/mo.../217-4156.html
11:72 set up? with 8" wheels
2013 Virginia Regional Finalist with 2356 and 2053
2013 FLR 1st Alliance Captain, Quality Award Winner
2012 FLR Finalists with 340,4124,and 3044
2012 Buckeye regional winners with 340 and 1507
Unread 08-01-2015, 01:18
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
11:72 with 6" wheels is a free speed of 21fps. Way, way too fast. Don't even try 8" wheels there.
11:84 with 6" wheels is good, but if you want to use the clamping gearbox you'll need two stages of reduction. Going 12:72, and then 16:22 via some sprockets to a versablock will net a free speed of 16.8fps, perfect for a 4-cim drivetrain. I don't know how mecanums will affect efficiency or handling at that speed though. You can go to 11:72 for the first stage to back down to 15.3fps if you want.
Unread 08-01-2015, 01:28
Chris is me's Avatar
AKA: Pinecone
This is still way too fast for a mecanum drive in this game. There's no need to go 15 feet per second when your biggest sprints are 1/4 length of the field... you're just wasting current. Mecanum drives do not work as well at very high speeds as west coast tank drives do.
I think for even 6" wheels, to use the clamp on gearboxes you really have to use the second reduction add-on to have good performance. Unless you're racing for the middle bins (and even then...) I would shoot for the 8-11 FPS range this year, but that's just me.
Unread 08-01-2015, 02:21
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
What do you define as a "very high speed" for mecanum? For me, high speed WCD is 18fps+ on 6 cims. For 4 cims, 17fps. Is mecanum actually that limited in terms of speed? I thought I read that they could go at least 15fps.
I don't think acceleration is a problem. A 15fps bot's time-to-distance is as good as or better than a 10fps bot for anything more than several inches. So you're not wasting current by running at a higher speed- it's very well used current.
EDIT: See here: https://www.youtube.com/watch?v=YbluSr2Mf5Q That's a 15.4fps mecanum bot.
DOUBLEEDIT: I would test both speeds actually. I have never seen anybody even try a mecanum geared for more than that 15.4 one I linked above, so I would try 12:72 x 16:22 AND 11:72 x 16:22 AND 12:72 x 16:32. I would be very interested to see actual results from a team that has tried a fast mecanum.
Unread 08-01-2015, 07:20
Hoover's Avatar
no team (None)
This is wonderful help, thanks.
Just for the record, If I had it to do I would strongly consider slide drive. I think mecanum will vibrate too much and if the robot (basically a fork truck) is carrying a stack of totes they could vibrate off.
We won't be having 4 independent suspension wheels with this setup. So that is not going to be a solution.
We also won't have encoders, but I think for us using the built in libraries this is not an issue.
But the drawback of slide drive is that I think the slide wheels will get caught on the lip of the loading platform even knowing it is tapered. In the best case it may cause an unwanted bump.
Unread 08-01-2015, 10:09
I think Chris' point was that you don't need 15fps for this game. But you do need fine control at near-zero speeds, as when aligning the bot to place totes and bins. A bot geared for lower top speed will have better fine control at low speeds.
Unread 08-01-2015, 10:53
jman4747's Avatar
jman4747 jman4747 is online now
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
We will be using the clamping gearboxes and 6" mecs with a 20t on the CIM (with 8mm-1/2hex adapter) to a 64t gear. Then the 64t gear's shaft attaches to a #25 16t sprocket which is linked to a 48t sprocket attached to each wheel. The 6" mecanums are attached to WCD bearing blocks tensioned with the cam.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 08-01-2015, 11:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
That certainly does work - that's how we did our robot last year. We used 6 inch mecanums and (I believe) the 10.7 TB minis Using 4 inch mecanum with the 8.45 is a bit lower, but that's good because you'll be carrying a heavier load and this is a slower-moving, though probably much faster scoring, game.
We were conisdering mecanum for our drive this year, but we were worried that the handling would change too much as we picked up the load (we're lifting outside of our chassis). The drivers even noticed it a bit just when we lowered our pickup arm on the practice 'bot (which was wooden and rather heavy) last year. We've opted for an H drive so that at least the direction of thrust will be what we expect, even if the accelerations shift a bit. We're figuring on putting the strafe wheel at the COG when we're carrying four or five totes (we're going to do up to six) so that it behaves well when carrying a full load (during scoring) at the cost of being a bit off-center when empty.
Last edited by GeeTwo : 08-01-2015 at 11:14. Reason: Forgot to address the thread directly!
