Go to Post Why is the battery labeled "battery"? - Vermeulen [more]
Unread 07-01-2015, 23:33
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Linear Guide Systems
You can find the engineering specifications here:
http://www.igus.com/iProsvc/Download...2 520WQ20.pdf
The carriage part is WW-10-40-10 and the max torque is listed as 125 lb-ft (170N). If each tote is 8 lb at a distance of 1.5 ft from the rail you'll exert a torque of 36 ft*lb on the carriage with three totes.
Looks like it should be OK. You can double the carriage and space them apart to give extra strength.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
