Go to Post (middle school age) One time I had a truly awful day at school and came home crying. My mother's response? "Do you want to go to the build session tonight? It will make you feel better.." And it did. It always does. - rachelholladay [more]
Unread 07-01-2015, 23:35
kuraikou's Avatar
kuraikou kuraikou is offline
AKA: Alex
FRC #4183 (Bit Buckets)
kuraikou is an unknown quantity at this point
Re: Has anyone tested out the viability of using hooks to lift totes?
my team has been toying with the idea, today we made a prototype and it worked pretty well
https://m.youtube.com/watch?feature=...&v=n7Nhm6VCoJ8
2012 Utah regional Rookie All Star
2013 Phoenix regional Judges Award
2014 Hub City Quality Award
2014 Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award
2015 Arizona East Regional winning alliance captain
Unread 08-01-2015, 00:03
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by ItsElectronic View Post
Is there a way to mount a hook on a timing belt so that it would be able to pass through a timing belt pulley?
Conceivably, you could pocket the pulley (or sprocket, if using chain, for that matter) where the hardware that's attaching your hooks would interfere.
That is -- provided that all of your pulleys were an even tooth count -- the link or section of belt with the hook attached will always mate with the same tooth when it arrives at the pulley. So, you could remove that tooth and create clearance for the hardware.
If you were to take the chain or belt off, you'd have to be very carefully when reassembling things to make sure the timing lines up the same way as it did initially.
--Madison--
...down at the Ozdust!
Unread 08-01-2015, 00:10
nixiebunny nixiebunny is offline
AKA: David Forbes
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Sure... it works great. We plan to use rollers (bearings) rolling along either side of a 1" square tube to do the guiding of the hooks. We prototyped this today and there's no problems that we could see.
We laser cut our hooks from 1/4" baltic birch plywood, using a narrow 7/32" wide hook, and no breakage even when bouncing it in different directions.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 08-01-2015, 00:44
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Another option is to use a wide belt. You could then use two narrow pulleys with a spacer between them, teeth aligned of course, or use a wide pulley and cut a groove with a lathe down the center.
Unread 08-01-2015, 09:46
matthewdenny's Avatar
matthewdenny matthewdenny is online now
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
You could use double strand chain and drive 1 strand and mount hardware on the other.
Unread 08-01-2015, 11:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I was thinking one of the VexPro VersaPulleys and something something the slice in the middle, but the keying makes that difficult. You could get a 2mm deep slot on either by taking off the teeth. On the 42 tooth, you can only get 3mm deep if you go down to the keying pins, it's up to 4.5mm deep on the 80 tooth.
Unread 08-01-2015, 12:07
baldenb's Avatar
baldenb baldenb is offline
AKA: Ben Balden
FRC #1540 (The Flaming Chickens)
baldenb has a spectacular aura aboutbaldenb has a spectacular aura aboutbaldenb has a spectacular aura about
We just got a box of these from McMaster today, when we get them working I'll post a review of how well they worked.
Unread 09-01-2015, 13:22
baldenb's Avatar
AKA: Ben Balden
The chain attachment points work great. Very sturdy and no problem holding the weight of 5 totes.
Unread 12-01-2015, 11:45
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
If you want to prototype a hook method - there's the rubbermaid fasttrack (and some other equivalent) that the hooks fit inside the lips on the short side: http://www.rubbermaid.com/Category/P...nizationSystem
Also, if you don't want to spend the money on the roller chain with tabs, you can stick an 8-32 bolt through the roller chain to transfer motion. You'll want to obviously do a few to reduce the stress on any one bolt: http://www.buildblitz.com/linear-elevator-concept/
Unread 12-01-2015, 11:51
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I'd be curious to see a picture of the setup and general geometry you used. Our current stacking design is planned to grab each tote individually, so will not see nearly as much load on each hook, but it's interesting to hear that you can pick up 5 with the lip of just one tote.
Unread 12-01-2015, 12:20
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
What was the other prototype if you don't mind me asking?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
