Go to Post I am a mechanical engineer. I have known since I was about 12 that I wanted to make complicated mechanisms. - Paul Copioli [more]
Unread 08-01-2015, 00:20
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Re: Visibility
I think for a video to be truly effective, it will need to be integrated with other sensors. Relying solely on a video feed for navigation will probably be lackluster.
Unread 08-01-2015, 00:21
Briansmithtown's Avatar
Briansmithtown Briansmithtown is offline
Pilot shortage, Good thing Im tall
AKA: Brian Sheridan
FRC #0810 (Smithtown Mechanical Bulls)
Briansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond repute
Re: Visibility
What about an Oculus rift!
2014 Team 810 Recap video https://www.youtube.com/watch?v=DS9K_j1FzF4
Unread 08-01-2015, 00:39
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Re: Visibility
I think there will be strategy to what order you stack when alliances get the capability to do it. Most likely when an alliance has the ability to stack all the bins they have had enough strategy to build a robot that good and to get them that far that they will have an order of stacking to avoid visibility problems.
Unread 08-01-2015, 01:44
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Visibility
To give people an idea of what you might see from the drivers' station I did this quick example. There are four recycle bins behind the stacks. See them? (Sorry, haven't applied materials for field yet.)
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 08-01-2015, 08:14
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: Visibility
That looks like a strategy issue. You'd want to place stacks starting at the backstop and working your way in towards the center, and bring any recycling containers from the step to the alliance station wall before you can't see them any more.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
