Go to Post We're still not ready for 2012.... - AdamHeard [more]
Unread 07-01-2015, 22:58
Naqib Shahan Naqib Shahan is offline
FRC #4528
Naqib Shahan is an unknown quantity at this point
Linear Guide Systems
Is the DryLin N Linear Guide Systems provided from the KOP a good choice as a guide to pick up multiple box. An arm is considered to be attach to it that will hold 3 or more boxes. Will the guide break and how will torque affect it? Overall thoughts????
Unread 07-01-2015, 23:33
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Linear Guide Systems
You can find the engineering specifications here:
http://www.igus.com/iProsvc/Download...2 520WQ20.pdf
The carriage part is WW-10-40-10 and the max torque is listed as 125 lb-ft (170N). If each tote is 8 lb at a distance of 1.5 ft from the rail you'll exert a torque of 36 ft*lb on the carriage with three totes.
Looks like it should be OK. You can double the carriage and space them apart to give extra strength.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 07-01-2015, 23:39
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
The drylin guides are great and won't break for this application. Torque will prevent a single slider from moving quite easily. If you have 2 sliders with a distance between them it will diminish the effect that a load will apply to it. It will also decrease your range of motion of the Drylin guide which may be a problem. If memory serves then the Drylin linear guides are 30" long. If you are trying to lift something >25" I would look at another option like www.Competitionrobotparts.com. If you have any questions feel free to PM me.
Unread 07-01-2015, 23:42
REVving up for a new season
FRC #2848 (All-sparks)
I will also shamelessly plug the REV Robotics extrusion system, It has built in v-grooves designed for smooth rolling of heavy loads. Check them out at www.REVrobotics.com
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 08-01-2015, 02:19
n1ckd2012's Avatar
n1ckd2012 n1ckd2012 is offline
oRyon Labs
AKA: Nick Dulworth
FRC #2587 (DiscoBots)
n1ckd2012 will become famous soon enoughn1ckd2012 will become famous soon enough
+1
Ri3D Team oRyon, 2014-Present
Ri3D 2015: Betelgeuse | Ri3D 2014: Draconis
2587 DiscoBots, 2010-Present
FRC 2012: Laser Dragon, Film, Build Log, Lone Star 3rd Seed Alliance
Vex 2012: Mini Dragon, Film, Math Division Finalists
FRC 2011: DiscoSlide, Film, 118 Parody, Lone Star Regional Finalists
Unread 08-01-2015, 07:21
kartikye kartikye is offline
AKA: Kartikye Mittal
FRC #4817 (One Degree North)
Team Role: Driver
kartikye is an unknown quantity at this point
How would we brace the REV system? I was trying to CAD it up yesterday and realized that the bases got in the way of the slider.
Unread 08-01-2015, 14:10
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Thumbs up Re: Linear Guide Systems
+2 I was part of the team indiana Ri3D group. Even without reinforcing it quite as well as we should have the REV extrusion with V-bearings worked flawlessly. Huge amounts of adjustability to get the spacing and squareness of the frame just right.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 09-01-2015, 15:36
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
We used the IGUS DryLin W track on the 2014 robot for our Spring guide system.
We are planning on using it again for the lift system this year as well. We would use 15-5M HTD belt to position the slider mechanism.
