Go to Post It is easy to be righteous on Chief Delphi, and harder to implement in life. - DonRotolo [more]
Unread 08-01-2015, 09:33
KeeganP's Avatar
KeeganP KeeganP is offline
AKA: Keegan
FRC #2059 (The Hitchhikers)
KeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of light
You can't break it, they said. Try, they said.
Quick disclaimer: I am not a programmer on the team, but I do some electrical work. 5 years FRC experience. And yes, I know the NI number to call -- I plan to have the programmers call during tonight's meeting since they know more about it than I do.
The problem:
Basically, we bought a roboRIO back a month ago or so, and that one works just fine. The brand new one in the KOP worked fine for two nights of testing (and driving on a 2013 robot), but then last night we ran into a bug. It stopped working
Copy pasted from the programmers:
-Imaging doesn't work.
-22 is closed, and 80 & 443 don't work (hangs in browser).
-Holding reset starts it back in "safe mode."
-Then, 22 works, but 80 & 443 still don't (presents an error).
-Updating firmware doesn't work.
- In both modes, web-based control doesn't work, and you have to use the USB cable.
- FTP rejects all users in both modes.
Any help is greatly appreciated -- have any other teams run in to a similar issue? To our knowledge, the RIO hasn't been set on any motors/magnets, and there are no metal shavings anywhere near it at all. We've checked the wiring, and it all *should* be correct according to diagrams, but we forgot to check the actual voltage coming into the RIO with a multimeter (but it worked fine exactly as it is setup for 2 nights, then randomly stopped...). Also, all of the above testing is with only power connected to it -- no sensors/Talons/etc.
Fortunately we have a backup roboRIO, but since we don't know what happened to the first one, we can't really prevent the same from happening to our second one... Thanks!
The Hitchhikers Team2059.org
2011 NC Regional: Rookie All Star Highest Seeded Rookie, 3459
2012 SCRIW: Champions, 2059
2013 NC Regional: Finalists, 2059 (Thank you 1539 and 2655!)
2014 NC Regional: Industrial Design Award, 2059
2014 THOR: Finalist, 2059
2015 Palmetto Regional: Gracious Professionalism Award, Finalists (Thank you 1533 and 1261!), 2059
2015 NC Regional: Industrial Safety Award, Engineering Inspiration Award, Winner (Thank you 1225 and 900!), 2059
