Go to Post The FIRST family is incredible. - Libby Ritchie [more]
Unread 06-01-2015, 01:39
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
LIDAR Sensor has arrived!
Just wanted to share that a new LIDAR (laser radar/rangefinder) is out on the market from "PulsedLight3D" for $90 -- Class I laser so it's FIRST legal. Just arrived today in the mail, and I hooked it up to my Arduino:
Did some initial testing via I2C, seems to be very accurate between ~20cm and 650cm (as far as I could test it tonight without finding a larger room), 0.5 deg beam width
Here's a snapshot of my Serial output with distance in cm (~100 Hz samples averaged and output at 5 Hz), sitting on my desk facing up to the ceiling.
http://pulsedlight3d.com/
We're going to have fun with this!
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 06-01-2015, 02:07
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: LIDAR Sensor has arrived!
We got ours today as well. Similar results to your tests. Very excited about this little guy.
Unread 06-01-2015, 02:42
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Being a geospatial geek, this is TOTALLY COOL!!!!!!!
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 06-01-2015, 08:24
TylerStaudigel's Avatar
TylerStaudigel TylerStaudigel is offline
FRC #0144 (R.O.C.K)
TylerStaudigel is an unknown quantity at this point
This might be a newbie question, but this can be connected to the robo-rio via the I2C and programmed in labview to give us the distance. Right. I haven't done much work dealing with I2C and am not sure what to expect.
Unread 06-01-2015, 14:47
seg9585's Avatar
AKA: Eric
The sensor has 2 output formats: I2C and PWM. I have tested via I2C and it works great. To use PWM, you'd need to create a low-pass filter to smooth the output which could then be read by the roboRio analog input.
I will be coding up a Java Class this week to interface with I2C on the roboRio, which I'd be happy to share.
My FIRST legacy:
Unread 08-01-2015, 00:15
tech2077 tech2077 is offline
AKA: Matthew Skolaut
FRC #3847 (Spectrum 3847)
tech2077 is an unknown quantity at this point
In case anyone is interested, I wrote up a java class for this, you can use the start/stop functions to use the built in updater Timer, or use the update function to only poll distance when needed.
LIDAR.java
Unread 08-01-2015, 00:40
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Ordered! I have been drooling over this for 6 months. And we might have a use for it. I was going to buy it for my self regardless. If it works out I will get one for the team so we have two.
Unread 08-01-2015, 06:21
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Based on the datasheet it seems this wouldn't work on polycarbonate, since it transmittance is just as high at 905nm as it is in the visible spectrum, and the laser would mostly go right through. I really don't know much about LIDAR systems, so does anyone else with more experience know if this would be the case?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 08-01-2015, 09:46
I asked this question on their forum.
https://groups.google.com/forum/#!forum/pulsedlight3d
Unread 08-01-2015, 10:27
Jared Russell's Avatar
Taking a year (mostly) off
Polycarbonate doesn't have 100% transmittance for near IR, but it's still very high. You will get a small amplitude return from polycarb, which will be higher if there are scratches or dirt on the surface, or if you are getting specular returns from other light sources. You can configure the LIDAR-Lite to present either the strongest, first, or last return to you, and I'd expect whatever is behind the panel to be the strongest return the vast majority of the time (but not always).
Experientially, LIDAR sucks for detecting transparent objects and requires lots of signal processing and integration of multiple scans over time to have any chance of accurately detecting a transparent object.
Unread 08-01-2015, 11:01
seg9585's Avatar
AKA: Eric
FYI, I have detected distance to transparent windows with moderate levels of success. I'd assume polycarbonate behaves similarly, but would have to do more testing. We are programming up the LIDAR against the roboRio tonight so I'll try it out.
My FIRST legacy:
Unread 08-01-2015, 11:06
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
For those that have these sensors, what is the jitter on the returned distance value you are receiving for a given period of time?
Does the returned value go unstable at any point in operation (i.e bouncing around different values) or is it pretty accurate, to what level of accuracy have you noticed? (i.e +/- 1 cm)?
Are you using the RoboRio or other embedded device to power and read the sensor?
Thanks for your response.
Thanks,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 08-01-2015, 15:17
dellagd's Avatar
AKA: Griffin D
Not quite. Glass is actually opaque to IR light, just like a piece of metal would be, while polycarbonate behaves just the same as it would in the visible spectrum (for a good bit). Things change when you move to different wave lengths, like, for instance, a black trash bag is totally transparent.
Unread 08-01-2015, 15:55
seg9585's Avatar
AKA: Eric
True for some IR bands but not near-infrared. Glass transparency doesn't drop off until approx 2000nm but this laser operates at 900nm.
One source:
http://www.molalla.net/members/leeper/transmis.png
My FIRST legacy:
Unread 08-01-2015, 16:12
dellagd's Avatar
AKA: Griffin D
One source:
Fair enough, then I'm curious how the LIDAR is operating as well as it does. Interesting.
