Go to Post Nats allows an exchange of a vast multitude of ideas from everywhere. Not only in robot design, but accents, tool storage, pit design, team spirt, clothing, many things. - Wetzel [more]
Unread 07-01-2015, 21:01
pavchag pavchag is offline
AKA: Paul Chaguine
FRC #5829 (AwtyBots)
pavchag has a spectacular aura aboutpavchag has a spectacular aura about
Re: [Ri3D] Team oRyon Presents Betelgeuse!!
H drive would be nice! But... its 3 days and not everyone can build an efficient Hdrive. I agree that H drive would be beneficial in some cases but it was not worth spending our time during the 3 days.
Unread 08-01-2015, 01:46
n1ckd2012's Avatar
Happy Birthday! n1ckd2012 n1ckd2012 is offline
oRyon Labs
AKA: Nick Dulworth
FRC #2587 (DiscoBots)
n1ckd2012 will become famous soon enoughn1ckd2012 will become famous soon enough
Originally Posted by AllenGregoryIV View Post
The version as mounted is actually just nuts sliding in the REV extrusion. A linear slide or the rev linear motion system would work far better. It also could work with just a single pneumatic if it had a linear bearing mechanism to keep it traveling straight with out jamming.
Yes. Our fork is the least complete system on the robot. The imaginary next iteration would use a more robust sliding mechanism. We took the brute force approach and used two massive pistons to prove the concept.
The point is, it can turn much more easily/smoothly than a 4WD with traction tires. And without the "rocking" of a drop-center 6WD.
Precisely! We recommend swapping out the front two wheels for traction wheels. You can still turn but you would be less "slidy" on the bump and your center of rotation would move forward towards the front of the robot which is desirable when manipulating totes.
Originally Posted by Madison View Post
If I say its name three times, will it appear in my lab?
Tried it yet? Last I checked it was still at Rice U.
Ri3D Team oRyon, 2014-Present
Ri3D 2015: Betelgeuse | Ri3D 2014: Draconis
2587 DiscoBots, 2010-Present
FRC 2012: Laser Dragon, Film, Build Log, Lone Star 3rd Seed Alliance
Vex 2012: Mini Dragon, Film, Math Division Finalists
FRC 2011: DiscoSlide, Film, 118 Parody, Lone Star Regional Finalists
Unread 08-01-2015, 07:34
dradoxen dradoxen is offline
CAD/Mechanical Mentor
AKA: Dominic Doxen
FRC #0910 (Foley Freeze)
dradoxen is an unknown quantity at this point
I think at about 1:40 in the video I see a CIM powered VersaPlanetary Gearbox directly driving a spool for your winching mechanism for your elevator. Can you confirm this? What is the final gear ratio in the gearbox and what diameter spool are you using?
Unread 08-01-2015, 11:10
n1ckd2012's Avatar
oRyon Labs
AKA: Nick Dulworth
That is correct. 1:70 versa planetary (1:7 + 1:10). The spool is something we found in a box and adapted. Its OD is roughly 4 inches. I imagine something similar could be found on McMaster. The most important part of a spool in this application is the sidewall height. You don't ever want your cable to slip off the spool. See attached pic.
We drilled some holes in it in order to mount a vex pro hex hub and another hole in the side wall to tie off the 1/16th cable.
To fasten the cable to the spool we tied a simple knot around the hole spool (like the first knot when tying a shoe) and passed the end through the hole drilled in the sidewall. We used a swage crimp as the main means of fastening the cable. If you used swage crimps, make sure you use the proper size crimp that is designed for your diameter cable and use a proper swaging tool.
Unread 08-01-2015, 11:27
Bryce2471's Avatar
Bryce2471 Bryce2471 is online now
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Just to clarify: Is 4" the od of the flange, or the where the cable spools up?
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 08-01-2015, 11:31
Brandon Holley's Avatar
Well done for 3 days, guys. A great example of a highly functional robot that any team could make.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 08-01-2015, 13:08
n1ckd2012's Avatar
oRyon Labs
AKA: Nick Dulworth
Where the cable spools up. An estimate =)
Unread 08-01-2015, 13:15
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Thanks a bunch this is very useful information
Unread 08-01-2015, 13:19
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
Love the video, and the lightshow your robots put on. Well done.
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 09-01-2015, 00:13
AKA: Paul Chaguine
We have 86 likes on our release video! Lets get to 100! Watch the video! Like the video and spread the word!
http://youtu.be/0KOSkMz1hTA
Lets inspire the community! I would like all of the teams that are going to build something similar to make major improvements to our design!
Unread 11-01-2015, 18:21
n1ckd2012's Avatar
oRyon Labs
AKA: Nick Dulworth
White paper! http://www.chiefdelphi.com/media/papers/3091?
Unread 11-01-2015, 21:43
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Are the arms on the lift a standard aluminum stock size? I can't seem to find much C-channel or angled aluminum that is smaller than 1" in either dimension.
Glad to see that some of the Ri3D teams arrived at similar design conclusions that our team did.
Unread 12-01-2015, 00:31
n1ckd2012's Avatar
oRyon Labs
AKA: Nick Dulworth
2x1 ripped down the middle of the 1 inch side.
kept it .5 in order to fit between the totes in the landfill.
Unread 12-01-2015, 12:25
The Arizona Mentor
AKA: Andrew
That strategy is specifically why I ask. We will want to keep our arms fairly narrow for the landfill but I want more resistance to bending than a flat stock of 1/8" aluminum is going to have when we hit something hard while turning.
Thanks for the idea!
Unread 14-01-2015, 19:40
promgmt's Avatar
promgmt promgmt is offline
AKA: S. Kelly
FRC #2990 (Hotwire Robotics)
promgmt is an unknown quantity at this point
Does the dimensions of your robot fit in the "Transport" frame? It appears that the wider dimension is across the forks and the shallower dimension is in line with the forks
