Go to Post Saying that something cannot be done, is always good inspiration for someone to find a way to do it. - Josh Hambright [more]
Unread 08-01-2015, 11:27
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Hot swapping code
Just wondering if anyone knows if the roboRIO supports hot swapping, or is it possible if I add some java parameters to the roboRIO to enable hot swapping. I have used hot swapping on my computer before but I don't know how the roboRIO VM works.
Unread 08-01-2015, 15:17
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Well, we use the standard Java se embedded JRE. You'll have to figure out how to get whatever environment you're using for hotswapping to connect to a remote JVM. The embedded profile we use is more limited than the full Java se, so you might have to create a custom JRE with more features.
This year, the code redeploy is really fast, like 7 seconds from compile to running. Is this really too slow that you need hotswapping?
Unread 09-01-2015, 10:28
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Re: Hot swapping code
We found that with 11 second compile times and 7 second reboots, we don't need to hot-swap anything.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 13-01-2015, 12:38
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
if you really wanted to, you could just make the 2 versions of code you want, say code A and B, separated by packages.
In the robot main class outside of packages A and B, run an init method to detect from the RIO a .txt file with a single character: A or B.
If A, call the Package A main class in teleopPeriodic(), etc.
If B, call the Package B main class.
This would only work with iterative, i don't know if it will work with Command or Simple.
This way you can just change a .txt file on the RIO and you don't have to recompile or rebuild, since both packages will be on the RIO. Dunno about memory usage though.
edit: you could also just do something on smartdashboard. that simplifies the whole txt file thing.
Unread 16-01-2015, 00:06
Ah ha, I did some more digging and I found this in the debug launch for the roboRIO
/usr/local/frc/JRE/bin/java -XX:+UsePerfData -agentlib:jdwp=transport=dt_socket,address=8348,server=y,suspend=y -jar /home/lvuser/FRCUserProgram.jar
So if i'm correct you should be able to hotswap code if you connect to the roborio over port 8348, I haven't tested it yet but I will be sure to post my results when I get into school tomorrow.
