Go to Post This is why I love this game. It's like high speed chess with flashing lights and lots of noise. - Karthik [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 06-01-2015, 12:03
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: 2015: Year of the Mecanum
Originally Posted by alopex_rex View Post
Has anyone done anything with using a gyro to correct mecanum issues? People have mentioned it in this thread but I couldn't find any examples online (all I found were examples of how to use gyros for field-oriented control, which is cool too). It seems like it would be fairly simple to, say, store the current gyro angle whenever you start going straight (i.e. not rotating), and have a PID controller change the "rotate" value to maintain the same angle as long as you're trying not to turn. Has anyone done anything like this?
I don't think "mecanum" even has a correct pronunciation; on our team we say me-CAN-um /məˈkæ.nəm/, but I think i've heard MEC-(a)-num /ˈmɛk.(ə.)nəm/, which presumably is where the "mecnum" spelling comes from.
Absolutely. It's not terribly complicated either. After all your meCHanum motor set speeds are calculated, mix in a component from the gyro useing a PID. Only do this when the driver is using the strafe functions. Disable it when he is turning.
Easy Peasy.
  #77   Spotlight this post!
Unread 06-01-2015, 12:29
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Originally Posted by alicen View Post
Whenever we did mecanums, we always had suspension on each wheel so that all wheels were always in contact with the floor. They even went over the humps in Breakaway just fine!
We did mecanums for logo motion with a flat-floor and they worked fine, but for rebound rumble, trying to climb the 'bridge' in the middle they were really problematic, even with suspension.
Remember that with mecanums, the left wheel is always pushing against the right wheel to make it go straight. So if one wheel gets off of the ground, your robot turns by itself.
Methinks that with a stack of totes on a forklift, the back-two wheels will be bumping off the ground regularly, and if you try to cross a platform at any kind of angle other than 90, you'll lift a wheel.
Last year I saw four wheel mecanums in the IAM14U frame, and maybe more often in 'butterfly' and 'octanum' drives. That that was acompletely flat floor. My recommendation is that if your heart is set on mecanums, use a butterfly or octo so you can put regular wheels on the floor when you need to. Also, note, the new frames are much more stiff than the old channel sections ones, so you'll need to do Something to keep those wheels on the ground. Something like independent suspension.
Mecanums work really well with Banebot transmissions too.
Last thing. Mecanums running over a noodle a problem? I think so . You tell me?
  #78   Spotlight this post!
Unread 06-01-2015, 18:49
My interpretation of the above is:
1) calculate the 4 motor speeds using the X and Y translation commands
2) calculate the motor speeds for rotation using the output from a PID
3) add the the corresponding speeds from (1) and (2).
Wouldn't it be more straightforward to compute the 4 motors speeds just once directly from the X, Y, and rotation commands?
BTW, what's the significance of the CH in caps?
  #79   Spotlight this post!
Unread 06-01-2015, 21:09
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
What I was thinking was a way of dealing with imperfect results from mecanum, i.e., if simply using WPILib's mecanum drive function results in the robot turning when it's supposed to be straight strafing. When the driver is trying not to rotate (the "rotate" value would be zero), store the current gyro heading. Then have a PID controller that tries to maintain that gyro heading, by setting the "rotate" argument for the function. So the PID would find the value that counteracts any undesired rotation caused by mechanical issues.
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
  #80   Spotlight this post!
Unread 06-01-2015, 21:11
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
This is exactly what we did in the past for our mecanum drive, and it worked wonderfully. We didn't have to obsess nearly as much about perfect weight distribution.
  #81   Spotlight this post!
Unread 06-01-2015, 21:35
See attachment
  #82   Spotlight this post!
Unread 06-01-2015, 21:42
alopex_rex's Avatar
AKA: Scott Morton
Nice chart--That's exactly what I was trying to describe!
  #83   Spotlight this post!
Unread 06-01-2015, 21:43
Aedan Hawke Aedan Hawke is offline
Metrobot
FRC #3324 (The Metrobots)
Aedan Hawke is an unknown quantity at this point
Originally Posted by Bruceb View Post
never used macanums before but really considering it this year. what is the prefered gearbox for these?
We've used mechanums for the last couple of years with success. Last year we made our own gearboxes and built them into our chassis. They worked exceptionally well but, obviously, were a huge drain on time. Other years we used Andymark ToughBoxes and those worked well for us. I'd recommend them unless you'd like the challenge of the custom gearboxes.
  #84   Spotlight this post!
Unread 06-01-2015, 21:47
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics), 694 (StuyPulse)
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
See attachment
Thanks, that diagram is helpful.
  #85   Spotlight this post!
Unread 06-01-2015, 21:59
Mecanum Wheel's Avatar
Mecanum Wheel Mecanum Wheel is offline
It's spelled mecanum
AKA: Bengt Ilon
Mecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond repute
Hi Aedan. Just for future reference, it's spelled mecanum. It's an easy mistake to make.
Is anyone using 6 inch mecanum wheels with CIMple boxes? We will be and are going for ~11 ft./s.
  #86   Spotlight this post!
Unread 07-01-2015, 00:41
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Talking Re: 2015: Year of the Mecanum
I think we may also going the CIMple Box route with the 6" standard Andymark mecanum wheels, with HTD belts geared for 12.5 fps.
In the past I have used a gyro just as stated above to keep the robot driving straight. It worked so well that we had a motor come disconnected and didn't notice for a few hours.
  #87   Spotlight this post!
Unread 08-01-2015, 13:28
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
See attachment
Wouldn't another option be to treat the feedback loop as the "rate controller" for the yaw axis? The rotation command from the joystick would be sent to the yaw controller. If it the command is zero then it will work as described in the attachment. If the command is greater than zero, then the controller will allow for more predictable rates of rotation based on the joystick command.
I believe this is how yaw control is managed on most RC Multicopters.
  #88   Spotlight this post!
Unread 08-01-2015, 14:16
What you've described1 would work; but if you're trying to hold position, it's best to close the loop on position, not velocity.
1 ... http://www.chiefdelphi.com/media/papers/download/2796 ...... http://www.chiefdelphi.com/media/papers/2390
  #89   Spotlight this post!
Unread 08-01-2015, 14:28
Saberbot's Avatar
AKA: David Ingraham
That makes sense. Thank you for creating these great resources.
  #90   Spotlight this post!
Unread 08-01-2015, 15:24
holygrail's Avatar
holygrail holygrail is offline
Gavin Wood
FRC #1939 (The Kuhnigits)
holygrail is just really niceholygrail is just really niceholygrail is just really niceholygrail is just really nice
We have 6" VexPro mecanums on our 2013 robot and we drove it over several noodles with no problem. There is a bit of bumpiness when you go over, so you might want to either stabilize the stack or just drive around the noodles when loaded, but that is true with any wheels unless you have suspension of some sort.
