Go to Post To limit FIRST to robots, tools, and competition is to strip away its immense potential. - Madison [more]
View Poll Results: How will you manipulate Recycle Containers
We will not be touching them 0 0%
We will only be able to push them 0 0%
We will only be able to pick them up if they are upright 12 27.91%
We will be able to right them and then pick them up 9 20.93%
We will only be able to pick them up tipped 8 18.60%
We will be able to pick them up in any orientation 14 32.56%
Voters: 43. You may not vote on this poll
Unread 08-01-2015, 14:04
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Tipped Recycle Containers
I was just wondering what teams are thinking of related to manipulation of the Recycle Containers this year.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 08-01-2015, 14:11
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Tipped Recycle Containers
Don't knock them over!! AND if you see them on one of the scored stacks of totes, DON'T get near that stack!!
I forsee a lot of teams with long crazy arm things, new drive systems, that are going to cause a lot of headaches for the teams that can build some impressive stacks.
Be prepared to pick up containers that are on their side.
Unread 08-01-2015, 14:20
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
'Snow Problem ran into this issue, the Recycle Containers are extremely tippy. You must be careful when trying to grab them, one wrong move and it will be sideways on the ground. I would suggest designing with that in mind. 'Snow Problem was still able to pick up tipped Recycle Containers but it was far from ideal.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 08-01-2015, 14:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
There should be an option "we plan to allocate some weight specifically to deal with that functionality, but how great it works depends on whether our prototypes work and are light enough".
Unread 08-01-2015, 14:36
Dhill098 Dhill098 is offline
AKA: Damian
FRC #2383 (Ninjineers)
Team Role: Driver
Dhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to behold
We are thinking that the chances of a bin being found tipped over are greater than finding them standing, and we also notices that they are more stable when lying on the top of the totes
Unread 08-01-2015, 14:45
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
I think we can plan on at least the middle 4 bins not being upright. It sounds like a good number of teams see them as a big goal and want them right away. (enough so that some will sacrifice auto points to get them sooner)
In the rush to get them to your side, people are likely not as worried about a clean grab.
