Go to Post When there appears to be something stupid wrong with a game (HPs outscoring robots, unreliable loading, autonomous that accomplishes nothing) I shouldn't complain about it. I should see it as a challenge to exploit! - Chris is me [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 05-01-2015, 13:36
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
COTS Elevator in Action
This is a video from Ri3D team O-Ryon:
https://www.youtube.com/watch?v=5PRBOK4l5xE
They're using Competition Robot Part's elevator roller kit:
http://www.competitionrobotparts.com/
I hope to see more great elevators like this one!
Thanks for your time,
Orion DeYoe
FRC Team 2252 "The Mavericks" 2011-2014 (Student)
FRC Team 5413 "Stellar Robotics" 2014-???? (Mentor)
2011: Drive Coach, CAD, Programming, Electrical
2012: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2013: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2014: Drive Coach, Strategy, CAD
2015: Team Founder, Design/CAD Mentor, Drive Coach
Unread 05-01-2015, 13:45
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Re: COTS Elevator in Action
Love the simplicity of the lift. I's assuming your just using weight of mechanism to keep tension on the rope?
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 05-01-2015, 13:50
Just to clarify, I'm not on the build team.
That being said, I believe they are just letting the weight of carriage tension the rope.
Orion DeYoe
Unread 06-01-2015, 15:44
mistersands mistersands is offline
FRC #4528 (Automatons)
mistersands has a spectacular aura aboutmistersands has a spectacular aura aboutmistersands has a spectacular aura about
This is almost exactly what we were thinking of doing. Does one kit cover all you need, aside from pullies and arms and such. Or would I need multiple?
Also, did they use wide or square frame?
We were thinking Long would help more with counterbalance.
Unread 06-01-2015, 15:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm not on ORyon either, but one of the members was at our design session last night.
Yes, ORyon is just using gravity to drop the elevator and tension the cable because c'mon man, it's a 3-day old elevator system!
Unread 06-01-2015, 18:49
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
The pulley and spool were separate parts from different companies.
I would not recommend pulley-spool approach because the cable will slip or come off the spool.
If you have the time, use a chain or timing belt system to avoid slipping on your elevator.
As for the linear slide itself, there are lots of options that are COTS but most are quite expensive.
We also prototyped with Rev Robotics Rail system and that will offers even more customization for elevator tower geometry than the robot compeition parts system.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 06-01-2015, 22:12
tbarban's Avatar
tbarban tbarban is offline
FRC #4825 (The Coltenoids)
tbarban is an unknown quantity at this point
How would you set up one of these chain or timing belt systems for use with an elevator? I haven't been able to think of a way this would work.
Pardon my noobness.
Unread 06-01-2015, 23:05
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Pardon my noobness.
You would make one complete chain run from bottom of robot to a tad higher than the highest point you want to lift to. You then would fasten your carriage to a certain section of that chain permanently. You would then rotate chain up or down and carriage will move with it.
(I am assuming you will be utilizing a single stage or "zero stage" where you just have a frame and then a carriage inside of the frame...the carriage being the only moving level.
-Ronnie
Unread 07-01-2015, 00:15
tbarban's Avatar
-Ronnie
Thanks Ronnie!
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Pardon my noobness.
I modified Craig Boezwinkle's drawing of 254's 2013 climber because it's essentially the same thing. I also attached an example (25 in 2011).
ID:	17766  Click image for larger version
ID:	17767  Click image for larger version
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 08-01-2015, 07:33
kartikye kartikye is offline
AKA: Kartikye Mittal
FRC #4817 (One Degree North)
Team Role: Driver
kartikye is an unknown quantity at this point
How did you guys brace the REV structure? I was trying to CAD it up yesterday but i realized that the brace got in the way of the bearing
Unread 08-01-2015, 09:33
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
This is a great example...but if you can stay away from multiple stages...please do.
Unread 08-01-2015, 13:44
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
I second this. As a part of the build team of 103 during 2011 (25 and us build twin bots that year with a few modifications for each of us), I highly suggest staying away from this many stages. The less stages the better. Although this lift did work very well, we had some significant problems with the belt stretching (Because it was so long), as well as some other problems.
Another thing to take not of in this design: The top lift (middle section in the picture of 25's bot) Had the grabber attached to the bottom of it, so the robot height was significantly taller than it needed to be when fully extended.
Other than that this lift worked extremely well for us, and we even made it to the finals on curie with that bot!
Unread 08-01-2015, 13:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
And since there's one height limit for the whole match, and nowhere to do "the limbo", a vertical multi-stage elevator for this game is unnecessary. On the other hand, maybe a horizontal one could be useful:
http://www.chiefdelphi.com/forums/sh...30&postcount=4
Unread 08-01-2015, 14:47
Mr V's Avatar
Mr V Mr V is online now
FRC #5588 (Reign)
While I wouldn't recommend a cable for use in a string and pulley set up I would highly recommend a paracord and pulley set up.
If your "string" can come off of the pulley then you haven't selected the right pulley/string combo or haven't put a shield on it to prevent the string from coming out of the pulley. It is all in the proper selection and/or design of the pulley to "string" interface.
Power down is also easy to do with the string and pulley set up. I recommend a divided drum and a captive spring tensioner to account for the possibility or variability in wrapping on the drum.
I don't understand why you would think that it would slip on the drum. The "string" should be anchored to the drum so no possibility of it slipping. You should not just wrap the string around the drum and tie it.
Millions of cars on the road today use a string and pulley set up for their window regulator and they last for many years. This method has been used for over 25 years.
Having used a chain driven lift on a number of competition robots over the years and using paracord and pulleys for the Team [REDACTED] Ri3D machine I would never choose a chain driven set up again. It is heavy, a pain to attach to and a pain to properly tension and problematic to repair quickly.
