Go to Post Blue Nitrile Tread is the best smelling wheel tread. #thingsyoufigureoutat2AM - Ginger Power [more]
Unread 07-01-2015, 13:46
jarotter jarotter is offline
Jorge Rotter
AKA: Jorge Rotter
FRC #5415 (Bears)
Team Role: Communications
jarotter is an unknown quantity at this point
Problem imaging the roboRIO
Hello everyone, we are having trouble imaging the roboRIO. We managed to update the firmware using a browser but the imaging tool displays this message. Did anyone else experienced this problem and knows how to solve it?
Unread 07-01-2015, 13:54
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Problem imaging the roboRIO
Restart the roboRIO. Worked for me.
Unread 07-01-2015, 14:00
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
I experienced this problem also, while imaging 2 differet robotRIOs, for 2 different teams, while using the same laptop.
First time, no problems (although the imaging itself takes a LONG time, and there doesn't appear to be a progress bar so I can't tell if its frozen), great.
Moved to the next roboRIO, and encountered that error. I had to close the imaging program, disconnect from the roboRIO (I was using USB), restart the roboRIO, plug the USB cable back in, wait a minute to make sure the device drivers installed, then turn the roboRIO back on.
Basically- Restart the roboRIO. I actually did a full power cycle, not just hitting the reset button.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 07-01-2015, 14:02
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
takes less than the crio did :O and old crio didnt have a progress bar either (though in total its longer since we have to load the JRE now)
Unread 07-01-2015, 14:06
AKA: Matt B
FRC #1771 (1771)
That is true, the old cRIO (both the 8 and 4 slot) did take a bit of time.
I guess I just like having progress bars, or something so I know the program didn't freeze.
I have noticed that I can cause the program to freeze (Have to close it via task manager) if I unplug the USB cable while it is connected to the roboRIO. (Haven't tried to do it WHILE imaging, I don't feel like bricking the roboRIO just yet... )
1771- Mentor (2015)
Unread 07-01-2015, 16:16
Jorge Rotter
AKA: Jorge Rotter
FRC #5415 (Bears)
We tried both things and even safe mode. Sadly, none of them worked. Any other ideas?
Unread 07-01-2015, 17:46
AKA: Matt B
FRC #1771 (1771)
Try a different computer if you can.
1771- Mentor (2015)
Unread 08-01-2015, 13:28
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is on a distinguished road
We had the same problem with our roboRIO using a toshiba laptop. So we tried doing imaging from our classmate and it worked fine. Originally we were using a toshiba laptop running windows 8. Every time we plugged in usb or powered on the roboRIO we got a popup on laptop referring to something about 'toshiba sleep/power mgmt'. It didn't occur to us that perhaps this msg was indicating the roboRIO drivers were not getting installed correctly for awhile. On the classmate (windows 7) as soon as we plugged in the roboRIO we saw msgs about NI/USBLAN driver being installed.
Unread 08-01-2015, 15:32
AKA: Matt B
FRC #1771 (1771)
Check the power settings of your Toshiba, specifically the Toshiba power management settings. I can't imagine those would interfere, but you never know. It's more likely the culprit was Windows 8.
We had issues with people on Windows 8. 8.1 worked better, and Windows 7 worked fine.
(For reference, I have a Toshiba Satellite P855-S5200, running Windows 7, but I disabled all the Toshiba power management, and just use the built-in Windows power management.)
1771- Mentor (2015)
Unread 09-01-2015, 16:20
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
If you really can't find anything try checking your computer's IPV4 setting on the Ethernet port and make sure that the IP address is set to auto and not some other random address.
Not sure if this will help at all but it solved the problem for us.
Unread 10-01-2015, 12:27
Rabell Rabell is offline
FRC #3802 (RoboPOP)
Rabell is an unknown quantity at this point
Has anyone else had better success with this? I running on a win 8.1 system, and have tried all of the various suggestions except for a different computer (that's next).
