Go to Post My driving skills are only slightly better than my dancing skills... - RoboMom [more]
Unread 08-01-2015, 15:57
nathanzentner08 nathanzentner08 is offline
FRC #2073
nathanzentner08 is an unknown quantity at this point
RobotDrive
Ive Created a RobotDrive with 4 controllers, and associated it to a Joystick. I do have 2 Victors that are working, which should be my left side. I have tested them with code using the set(.50) and they both work.
drive = new RobotDrive(vic01, vic02, vic03, vic04)
drive.arcadeDrive(stick);
when I go into teleop mode, I get a message "Robot Drive... Output not updated enough"
1) I do not have vic03, or vic04 connected. (Assuming that the left side should work regardless of the right side failure.
2) Im assuming that associating a drive with controllers and then associating a Joystick to the drive is going to automatically allow me to control movement of my motors.
3) Im assuming that I will not have to capture inputs from the joystick and translate them myself to the motors.
4) I have opened the SRC of the edu.wpi.first libs and searched for this message. I could not find it anywhere. What is the standard logging mechanism that writes to the Riolog? (System.out, Log4j, Other?)
Unread 08-01-2015, 16:27
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: RobotDrive
Try disabling the safety on the RobotDrive with
drive.setSafetyEnabled(false)
This is the timeout between updates of the RobotDrive. It really isn't super important to keep it enabled, but if you want to enable it, then try timing your code and set the timeout longer than the loop that is calling arcade drive.
About the RioLog, anything printed to stdout or stderror will appear in the log.
Unread 08-01-2015, 16:42
FRC #2073
Re: RobotDrive
So that solved my "Robot Drive... Output not updated enough" issue and I did find that message in MotorSafetyHelper, so I was close,
But what about 2, and 3
Unread 08-01-2015, 16:51
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
Re: RobotDrive
Yes, the code you have should allow you to drive with that Joystick. You should not have to manually write code to get stick values then write them to the motors. Robot drive will do this for you.
Unread 08-01-2015, 16:54
FRC #2073
Re: RobotDrive
Now that Im reading further into the demos, it looks like you do have to keep pulling the value of the
2) Im assuming that associating a drive with controllers and then associating a Joystick to the drive is going to automatically allow me to control movement of my motors. (FALSE)
3) Im assuming that I will not have to capture inputs from the joystick and translate them myself to the motors. (FALSE)
In the operatorControl method, they are looping and polling. I thought it was going to be more event driven.
Unread 08-01-2015, 16:55
WPILib Developer
FRC #0190
Re: RobotDrive
Those assumptions are incorrect. Every time you call drive.arcadeDrive, it will update the speed controllers with the new values. The drive methods that take a joystick are simply convenience methods that save you the step of getting the joystick axes and passing them into the RobotDrive object. With safety off, the motors will continue to drive at the last set speed until you disable the robot or it runs out of power.
Unread 09-01-2015, 00:13
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: RobotDrive
just to make sure, you aren't calling the constructor (drive = new RobotDrive(vic01, vic02, vic03, vic04) every time in the loop, you just have that once in robotInit()?
