| Thread Tools |
Rating:
Display Modes |
Questions about elevator and R18
Hey guys,
Our team is looking into an elevator that only has to lift the totes 1 foot into the air, but must be strong enough to lift five totes at once (the totes will be stacked on top of the elevator via another non-elevator apparatus). We thought we might use a linear actuator (motor) but that might not work as they are expensive and do not often come in 12" lengths and still be DC 12 volts. So does anyone know of a good linear actuator (motor). Secondly, if we were to use a chain and motor for a pulley, how would we connect the chain to the vertically sliding forklift? I'm sorry if this a simple rookie question, but we came in during Arial Assist and have no experience with elevators. So I am looking for the name of the part used to connect a chain to a metal channel. My last question has to do with rule R18. What does it mean by a 1" stroke size for the solenoid actuator? Also do the mini-CIMs count towards the CIM limit? Thanks a ton for al of your help! |
Re: Questions about elevator and R18
On the subject of linear actuators that can extend 12 inches, check this out:
http://dartactuators.com/ |
But I would really like to know how to connect a chain to an aluminum channel. Or is using fishing line connected to a sand paper pulley better? |
http://www.andymark.com/SearchResults.asp?Search=dart
This makes it look like they released it but everything is out of stock. I'm not sure when that will change. |
Why cant you use a pneumatic cylinder???
Do you need more than 2 positions? The linear actuators is a much more complicated item than a piston. |
#7
Mini-CIMs are counted separately in the rules. Review the list of motors in R18, only CIM motors have a capped quantity.
#8
Other teams have placed bolts through the chain links as well and attached them to brackets mounted to the elevator carriage. Here is an excellent post that should give you an idea of what I think you are looking for: http://www.chiefdelphi.com/forums/sh...84&postcount=8 Good luck with your elevator! |
#10
Thanks for all of your help.
www.youtube.com/watch?v=-DBmbtBd6bg Anyway, thanks for all of your help! |
