Go to Post I trust in Martus. - Petey [more]
Unread 08-01-2015, 20:43
Re: Driver Station CONNECTION ERROR!
If you can successfully ping the roboRIO, it probably isn't a hardware problem. Have you made sure your computer's network interface is set to DHCP? The IP address shouldn't matter, but the netmask and default gateway might be confusing things.
