Go to Post I've always suspected that one could find glimpses of wisdom, setting priorities, and responsibility - and ways to balance them, in the contents of a coffee cup. - JaneYoung [more]
Unread 06-01-2015, 23:37
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
roboRIO not found
I've been having some trouble programming/debugging the RoboRIO. This is the tail end of the output I see in the console when attempting to deploy:
get-target-ip:
     [echo] Trying Target: roboRIO-488.local
Unknown host: roboRIO-488.local
     [echo]  roboRIO not found via mDNS, falling back to static USB
     [echo] roboRIO not found via USB, falling back to static address of 10.4.88.2
BUILD FAILED
C:\Users\John\wpilib\java\current\ant\build.xml:45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
I can ping roboRIO-488.local successfully. I can also read the files on the roboRIO via FTP.
In Window->Preferences->WPILib Preferences, my team number is set to 488.
The roboRIO has been imaged with the v23 image (and I can confirm with the tool). I can also see and operate the robot via the Driver Station.
By plugging in the USB cable, I am able to program the robot. Also, the debug environment seems to only try connecting to roborio-488.local, and doesn't work via USB.
Any idea what's going on?
Unread 07-01-2015, 00:00
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: roboRIO not found
Did you install Java on the rRIO?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 07-01-2015, 11:47
FRC #0488
Yes, using the JVM Wizard from FIRST.
Unread 08-01-2015, 20:10
FRC #0488
I did a little experiment.
First, using cmd.exe, I pinged roboRIO-488.local:
C:\Users\John>ping roboRIO-488.local -4
Pinging roboRIO-488.local [169.254.82.206] with 32 bytes of data:
Reply from 169.254.82.206: bytes=32 time=1ms TTL=64
Then I went into C:\users\john\wpilib\java\current\ant\build.xml, and modified this:
<property name="target" value="roboRIO-${team-number}.local" />
into this:
<property name="target" value="169.254.82.206" />
I was able to deploy code successfully.
The question is... why is Eclipse unable to resolve roboRIO-488.local, while Windows (via cmd and explorer) can resolve it easily?
Unread 08-01-2015, 20:18
Typically this is due to a firewall only blocking certain applications.
Unread 08-01-2015, 20:33
FRC #0488
Good thinking... though I already tried disabling the Windows Firewall entirely, to no effect.
Plus, Eclipse has no issue connecting to the roboRIO, as long as I refer to it by IP and not by its mDNS address (roboRIO-488.local).
Unread 08-01-2015, 20:46
FRC #0488
As a workaround...
Is it possible to modify the WPI plugin to get the debug command to use an IP address target instead of the "roboRio-488.local" address? And if so, how?
Unread 08-01-2015, 21:27
FRC #0488
Well, instead of modifying the plugins, I decided to modify my machine.
I edited my hosts file (C:\Windows\System32\drivers\etc\hosts) to include this line:
169.254.82.206 roboRIO-488.local
This allows deployment and debugging without modification of build scripts or anything... but is obviously somewhat fragile. Hopefully I can root cause the actual issue in the meantime.
Unread 08-01-2015, 22:15
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
As a workaround...
This would be possible by modifying the ant script in the ~/wpilib/java/current/ant/ directory, but that'll run into the same issue as a hosts workaround, which is that the roboRIO ip could change. As it is, we default to mdns, but fall back to static USB and old-style 10.te.am.2 if mdns isn't found.
Unread 08-01-2015, 23:35
FRC #0488
The problem I had there is while I could edit the ant script to deploy code, it seemed like Eclipse would always attempt to connect to "roboRio-488.local" when opening the connection to the remote debugger.
Is there a way to mess with that?
Unread 09-01-2015, 00:10
WPILib Developer
FRC #0190
Well, you could theoretically make a new ant run config that runs the debug-deploy target, and a new remote debug configuration that connects to the remote jvm session. I haven't tried it, but I just went and looked at the plugin source, and I think these are the parameters you'll need to set:
Connection Type: Standard (Socket Attach)
Host: <YOUR IP HERE>
Port: 8348
No guarantees that these are the actual correct parameters, as I didn't write any part of the plugin, but if I'm reading it correctly, then that's what you're looking for. If you're interested in taking a look yourself (if that doesn't work), then visit https://usfirst.collab.net/sf/projects/wpilib/ and follow the instructions to look at the source. The particular file I'm pulling this info from is eclipse-plugins/<long package name>.java/src/main/java/<more packages>/launching/JavaLaunchShortcut.java, in the getRemoteDebugConfig method. Hope that helps.
Unread 10-01-2015, 23:45
fredghostkyle fredghostkyle is offline
4908 Web Master and Marketing
FRC #4908 (Duxbury Robotics)
Rookie Year: 2015
fredghostkyle is an unknown quantity at this point
Have you tried roborio-0488.local?
Unread 11-01-2015, 13:49
FRC #0488
That address does not resolve for me. Interesting idea, though. =]
Unread 11-01-2015, 14:00
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
What OS are you running?
Unread 11-01-2015, 15:59
FRC #0488
Windows 7.
