Go to Post For what it's worth, while they may or may not be legal as safety glasses, Steampunk goggles are perfectly legal as forehead protectors. - Nuttyman54 [more]
Unread 08-01-2015, 19:14
CLeonard CLeonard is offline
FRC #5107 (The Neurotoxins)
CLeonard is an unknown quantity at this point
USB Camera Issues
We are trying to view the images on the Dashboard by calling the Java CameraServer class, but we get nothing. Has anyone figured out how to view the images from a USB camera plugged into the roborio or does anyone know if there is a separate program for usb cameras?
(We are using a PS3 Eye camera if that makes a difference.)
Any suggestions?
Unread 08-01-2015, 19:19
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
Re: USB Camera Issues
The java example projects "Simple Vision" and "Intermediate Vision" both show how get an image from a usb camera and how to put it on the driverstation.
http://imgur.com/cMKc9YJ
Unread 08-01-2015, 19:48
We have tried running both of those programs on the roborio with both a user defined name (e.g. "cam0") and the resource name. We haven't gotten anything back from either. Both report the supposed camera's fps, but there is no indication that the camera is being used.
Any ideas to troubleshoot it?
Unread 08-01-2015, 19:50
Did you make sure the camera shows up in the web dashboard as cam0? I can't find anything that says the PS3 Eye is supported by GenICam.
Unread 08-01-2015, 19:54
By default it has no name, so we define it as cam0. The name is saved between web sessions, but is lost on shutdown/power cycle.
Unread 08-01-2015, 20:31
Joey1939's Avatar
Joey1939 Joey1939 is online now
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
On our test board mDNS isn't working, so the USB Camera viewer on the SmartDashboard gave an error that it couldn't connect to roboRIO-1939.local. We went into the SmartDashboard preferences and disabled mDNS (We set a static ip on the roboRIO). With mDNS disabled the USB Camera worked just fine.
Unread 08-01-2015, 20:46
We can connect to the roborio just fine and test the motor controllers and joysticks. I haven't set up the wireless yet, so we are using usb to connect to the roborio. I'll set up the router and test if we can view it then.
Unread 08-01-2015, 20:54
http://www.chiefdelphi.com/forums/sh....php?p=1423773
This thread recommended the ps3 eye and other people seemed to think that it should work.
Unread 09-01-2015, 00:47
Merfoo's Avatar
On the dashboard did you guys change the type of camera to get feedback from?
Unread 09-01-2015, 00:51
Yes, we tried all options for camera feedback.
Even though there is no visual and the camera's indicator light is off, the dashboard still displays an fps. Should it?
Unread 09-01-2015, 16:01
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Can you try another camera? The PS3 Eye may not be support natively by the roboRio.
Unread 09-01-2015, 16:22
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
I had posted in that thread that the PS3 eye works on the beaglebone and Jetson TK1. For the Jetson board I had to compile & install a kernel module before I could get it working. I suspect the same may be true for the roboRIO, though I have not begun to investigate.
The easiest route would probably be to use the HD3000 since this is what was developed & tested on. Is there a specific need to use a cheaper camera as the OP of the thread you linked had wanted?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 09-01-2015, 16:40
I believe the PS3 Eye camera is support by Video4Linux. It should be possible to install that and use it on the roboRio, correct? That should allow access to the Eye camera.
Unread 09-01-2015, 20:49
When I had posted this question I was under the impression that the other programmers had installed the appropriate drivers when I was away. That wasn't the case, so we are now using a new camera.
For any teams looking to use a PS3 Eye camera, you will need to use the gspca-ov534 ARM drivers. It seems to require make to install(which the roborio doesn't have), so you will have to manually download and extract the drivers for roborio install. It isn't worth it imo, but if that's your only option, start your search with gspca-ov534.
