Go to Post ... the team that *DOESN'T* design things in the offseason for prototyping and testing will always be at a much bigger disadvantage. - Cory [more]
Unread 08-01-2015, 20:52
1452-Leo 1452-Leo is offline
FRC #1452 (Omnicats)
1452-Leo is an unknown quantity at this point
Eclipse can't find RoboRIO
We have been having trouble uploading code to the RoboRIO when connected over wifi. It works fine through ethernet, but wifi gives this error:
get-target-ip:
        [echo] Trying Target: roboRIO-1452.local
Unknown host: roboRIO-1452.local
        [echo]  roboRIO not found via mDNS, falling back to static USB
        [echo] roboRIO not found via USB, falling back to static address of 10.14.52.2
BUILD FAILED
/Users/*****/wpilib/cpp/current/ant/build.xml:45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
Does anyone know what could be causing this? We've had the same result with two different Macs. We also tried pinging roboRIO-1452.local and nothing came up. Thanks!
Unread 08-01-2015, 21:03
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: Eclipse can't find RoboRIO
From the sounds of it you are probably running into this.
http://www.chiefdelphi.com/forums/sh...hreadid=132337
Check the IP address of the Wireless Network Adapter on your computer.
System Preferences -> Network -> Wifi. Most likely it will not be 1.14.25.x.
As far as I know the only work around is to manually configure an IP address on your laptop.
IP: 1.14.25.6
Subnet: 255.255.255.0
Setting a manual IP on a mac.
http://www.macinstruct.com/node/550
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 08-01-2015, 21:08
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
If you used the Router Configuration Tool the DHCP should set the ip to 10.x.y.20 - 99, x.y being your team number and the last part ranging from 20 to 99. Make sure the DHCP server is setup on your DLink.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 08-01-2015, 21:09
Unfortunately I'm no longer with the robot, but I ran an "arp -a" while I was there and here are the results:
? (10.14.52.255) at ff:ff:ff:ff:ff:ff on en1 ifscope [ethernet]
? (17.173.254.222) at (incomplete) on en1 ifscope [ethernet]
? (17.173.254.223) at (incomplete) on en1 ifscope [ethernet]
? (224.0.0.251) at 1:0:5e:0:0:fb on en1 ifscope permanent [ethernet]
I'll try both of the suggestions above and get back with results tomorrow. Thanks for the help!
EDIT: I changed the dLink to DHCP mode and it works! Does anyone know why this doesn't happen by default?
