Go to Post However, mentoring isn't for you. It's for the others. - Alan Anderson [more]
Unread 08-01-2015, 21:48
thetonio96 thetonio96 is offline
FRC #4635 (Eugenio)
thetonio96 is an unknown quantity at this point
Post getRawButton() problems
Hi everyone, our team is programming the robot with Java, but we are have a problem getting the boolean value of getRawButton() method. Does someone had a similar problem or knows how to fix it?
//Example
public void teleopPeriodic() {
if(stick.getRawButton(1)==true){
//Some Code
Unread 08-01-2015, 22:00
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Re: getRawButton() problems
Does anything else on the controller work?
Unread 08-01-2015, 22:04
FRC #4635 (Eugenio)
Yes, the RobotDrive is getting the X and Y axis and they are both working.
Unread 08-01-2015, 22:06
AKA: Alex
Did you look under the driver station joystick menu and see if the button is being read there?
Unread 08-01-2015, 22:08
FRC #4635 (Eugenio)
Yes, also did that with each button and they all blink the green light in the driver station.
Unread 08-01-2015, 22:10
AKA: Alex
Are you sure its the right port for the button? Do you mind sharing the rest of your code?
Unread 08-01-2015, 22:11
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Even though it is for C++, this problem sounds suspiciously similar: http://www.chiefdelphi.com/forums/sh...hreadid=132426
Unread 08-01-2015, 22:16
AKA: Alex
It sounds like might be an issue just for that controller. Did you try other methods like getButton and getTrigger?
Unread 08-01-2015, 22:23
FRC #4635 (Eugenio)
Ok, so this https://gist.github.com/antoniotorre...9be53daa4f6a18 is the test code that we are using to test the controller's buttons. The basic idea is that the spikes turns on, which it does on the autonomous mode.
Unread 08-01-2015, 22:35
AKA: Brad
#0190 ( Gompei and the Herd)
What model joystick is it? And can you try another joystick type to see if that works?
Brad Miller
Robotics Resource Center
Unread 08-01-2015, 22:39
FRC #4635 (Eugenio)
Yeah, we tried with the Logitech ATK3 and the Xbox Controller and both have the same issue.
Unread 09-01-2015, 00:21
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
//Some Code
Just remember that this should return a boolean, so you don't need the == true
just try, it simplifies the code and leaves less room for error.
        if(stick.getRawButton(1)){
                //Some Code
Unread 09-01-2015, 07:47
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
We ran into an issue like this yesterday. Make sure you have your joystick set on the right port. Everything shifted to a 0 index this year on the rio and the driver station.
Not sure if this is the case for the buttons and axis or not though.
Unread 09-01-2015, 10:25
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Something that our team found was that all of the axis and button numbers don't directly translate from the 2014 control system to the 2015 control system. We use Xbox controllers and previously, the left joystick Y axis was axis 5, but in the 2015 code it is recognized as axis 1. I would recommend making a test program and iteration through all the axis numbers and the button numbers and writing them all down for future use.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 09-01-2015, 11:34
Have you looked at the display on the USB tab of the driver station? It does the same thing.
