Go to Post (i would watch out for those jag's if i were you) - Scott Bahl [more]
Unread 08-01-2015, 20:45
16flippinb 16flippinb is offline
FRC #5216 (Team 5216 "The E-Ville Empire")
16flippinb is an unknown quantity at this point
Can you extend outside your frame in recycle rush?
My team was having trouble interpreting this years rule book. We are thinking of having arms that extend out of our robots frame in order to pick up and stack crates. The rule in question is 4.2r3b where it notes a travel configuration of 28"x42"x78" being met with minor disassembly. Does this mean that our robot may have one configuration for travel that fits inside the dimensions, but after minor disassembly at a competition site has a different configuration with arms to lift crates which extend past the 28" width or 42" length before the beginning of the match?
The definition of transport configuration in the glossary notes "transferring robots between locations (e.g. the teams's pit, the practice field, inspection, the arena, etc.). Might this mean our robot can extend out beyond these dimensions for length and width before a match begins with minor modifications as long as it can be moved from between these places within the specified dimensions?
Unread 08-01-2015, 20:51
Taurus Robotics's Avatar
Taurus Robotics Taurus Robotics is offline
FRC #4818 (THE HERD)
Team Role: Student
Taurus Robotics is an unknown quantity at this point
Re: Can you extend outside your frame in recycle rush?
Yes, you are correct. The robot can have parts that when attached to the robot extend beyond the transport requirements when on the field, but it can only be 78'' tall. Keep in mind that attachments must be easy to put on and should not delay the start of a match.
Unread 08-01-2015, 20:53
This is the meaning of the rule.
Let me put it another way, that might be clearer: When your robot is ON the field, it can be any size as long as it is less than 78" tall (and meets any implicit size constraints, like not occupying part of the Auto zone or Landfill prior to match start). When your robot is IN your pit (or other similar areas), it can be any size, again with the limitation of implicit size constraints (10' square pit area, for instance).
But when your robot is MOVING between such places, it must be within the Transport Configuration size, and you will need to convert it to and from from Transport Configuration (if necessary) within about 1 minute.
Unread 08-01-2015, 22:36
Okay so you could have a bolt on, bolt off arm that could be attached to the robot in a timely manner before a match?
Unread 08-01-2015, 22:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Yes.
Unread 09-01-2015, 08:51
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
Yep. Make sure you can get your match configuration set up on the field in less than 60 seconds.
G11
DRIVE TEAMS may not cause significant or repeated delays to FIELD reset at the conclusion of the MATCH. VIOLATION: YELLOW CARD
DRIVE TEAMS are expected to remove ROBOTS from the FIELD after the MATCH safely and swiftly. As a guideline, ROBOTS should be configurable in fewer than sixty (60) seconds. DRIVE TEAM efforts that either intentionally or unintentionally delay the FIELD reset process are not allowed. Examples of such delays include, but are not limited to: A. prolonged assembly/disassembly of a ROBOT to transform it to its TRANSPORT CONFIGURATION B. taking an excessive amount of time to exit the field after a MATCH is complete
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 09-01-2015, 10:35
Riverdance's Avatar
Riverdance Riverdance is offline
AKA: Beth
FRC #5686 (Wirecats)
Riverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud of
In addition, something that my team noticed immediately this year was the lack of constraint regarding the size of extensions outside the frame. A change from last year, when extensions could only be 20" or less. Your robot can be as long/wide as you want this year as long as it can fit into the transport configuration when disassembled/retracted.
Unread 09-01-2015, 10:44
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
You can be as long or wide as you want as long as you remain inside the field. I can guarantee that a 10 foot arm swinging outside the field smacking a Ref or FTA will be met with very little amusement.
Unread 09-01-2015, 10:52
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (Ctrl-Z)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Keep in mind the Q and A update, all zones are defined as a volume. Therefore, whatever extends out of your frame must start completely inside the allowed staring zones' invisible planes extending infinitely upward.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 09-01-2015, 11:27
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
In addition to the sixty second setup/takedown, make sure your transformation takes less than sixty seconds with two people. Only drive teams are allowed onto the field to set up the machines in qualifications, and the way queuing works at events usually necessitates one person to go right to the alliance station wall and another person to wheel over the cart to another area.
So, only two people will be able to set up over the course of sixty seconds (you also may not want too many pairs of hands on your robot to make transforming more efficient). Depending on how elaborate your robot setup has to be, you will want to consider modularity in your design for parts extending outside of the TC, and train the drive team on expeditious setup.
Unread 09-01-2015, 22:30
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
60 seconds setup and takedown is important ,a team can not delay matches.
