Go to Post My most distinct memory was watching Tom fix our robot's frame... by whacking it with the hammer. - Jaine Perotti [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 09-01-2015, 04:19
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Re: Using speed PID controlled mecanum with Holonomic Drive.vi
Originally Posted by Joe Ross View Post
A Talon SRX isn't magic. Whether you try to run a velocity PID on the Talon, or in your LabVIEW code, tuning the PID control values is hard.
I know that, but I need help with adding PID control to normal controllers because the only examples I have seen use CAN.
Unread 13-01-2015, 16:00
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
You take the motor setting outputs from the Holonomic VI and multiply them by the max rpm value you will see from your encoders. Then wire the setting into the PID VI "set point" and the encoder rpm value into "process variable". The output range should be 1 to -1.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
