Go to Post If robotics is bad for you, well then I guess I'm gonna die. At least I'll die happy. - karinka13 [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 08-01-2015, 08:23
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Question Using speed PID controlled mecanum with Holonomic Drive.vi
I'm trying to program mecanum drive with speed PID for each motor.
I want to do this in order to set the rotation speed of each wheel rather than setting power (-1 to 1).
I've noticed that it can be easily programmed using Talon SRX CAN,
but unfortunately our team will not get them soon and because they are out of stock we fear that we won't be able to get 8 of them for both competition and training robots.
So, I need help with programming mecanum drive with PID speed control because I don't know how to integrate this into the excellent Holonomic drive which I wish to keep using.
Thanks.
Unread 08-01-2015, 11:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Using speed PID controlled mecanum with Holonomic Drive.vi
Vex Robotics has Talon SRXs in stock. They'll even ship today if you order in the next 3 hours. Hurry!
Seriously, though. What's with everyone thinking SRXs are out of stock?
Unread 08-01-2015, 12:03
A Talon SRX isn't magic. Whether you try to run a velocity PID on the Talon, or in your LabVIEW code, tuning the PID control values is hard.
Unread 09-01-2015, 04:19
GuyM142's Avatar
AKA: Guy
I know that, but I need help with adding PID control to normal controllers because the only examples I have seen use CAN.
Unread 13-01-2015, 16:00
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
You take the motor setting outputs from the Holonomic VI and multiply them by the max rpm value you will see from your encoders. Then wire the setting into the PID VI "set point" and the encoder rpm value into "process variable". The output range should be 1 to -1.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
