Go to Post The mission is to mobilize community, school and corporate resources to support the vision. The method is to provide an interesting, exciting program that gives young people opportunities to explore and expand their capabilities and interests. - Rick TYler [more]
Unread 09-01-2015, 08:52
nHoude's Avatar
nHoude nHoude is offline
Robot Enthusiast
AKA: Nathan H
FRC #3467 (Windham Windup)
Team Role: Electrical
nHoude is an unknown quantity at this point
Re: Vaccum System
Originally Posted by Nesquik View Post
So are any certain vacuums considered illegal?
Yes and no. The vacuum itself is not illegal, but usually the motor powering it is. If you would like to to use a vacuum, you need to look up the specs of the motor in the vacuum and replace the motor with a similar FIRST legal motor.
For more information on what motors you can use please read R18 (under 4.7 Motors & Actuators).
Game Rules Link
https://rps01.usfirst.org/frc/manual...GameManual.pdf
FIRST Motors Specs
https://rps01.usfirst.org/frc/manual...nformation.pdf
Unread 09-01-2015, 10:41
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
Re: Vaccum System
You could also do what we did in 2004, and make your own vacuum pump. All you need is a motor and a pneumatic cylinder. As far as I know this would be legal under this year's rules, but there may be something in the manual I missed. (Pro Tip: Even if your frame is welded box aluminum, don't try to use it as an accumulator.)
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
