Go to Post FIRST is a worthwhile program to be involved in as an Adult mentor. But for me, it does bring its share of personal conflict. ..... Cuz' you know when Jan 4/5 comes round' I'll be itchin to go gang busters again. I'll never learn - PMGRACER [more]
Unread 09-01-2015, 09:04
jszipszky jszipszky is offline
FRC #1168 (FriarBot)
jszipszky is an unknown quantity at this point
Re: Mechanum with XBox Controller
Originally Posted by Ethan_P View Post
for mechanum wheels, our team also uses a Xbox controller. We have the right joystick axis mapped to the linear movement of the robot, and the the left joystick x axis mapped to the rotation.
Here's a simplified version of our code:
//FLMotor = Front Left Motor
//FRMotor = Front Right Motor
//BLMotor = Back Left Motor
//BRMotor = Back Right Motor
//x = right joystick, x axis
//y = right joystick, y axis
//yaw = left joystick, x axis
FLMotor = y + x + yaw
FRMotor = y - x - yaw
BLMotor = y - x + yaw
BRMotor = y + x - yaw
The values will have to be limited, other-wise it will go beyond the accepted values (-1 to 1). Make sure the wheels are set up properly, and good luck!
We do something very similar to this. I don't want to hijack this thread but how are you limiting the values? Right now in our rough code we have a mess of if-elses determining if the values are over 1. I imagine that there is a better way to do this?
Unread 09-01-2015, 09:06
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Okay thanks guys! Ill let you know if I can get it to work
Unread 10-01-2015, 22:39
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Our team uses mecanum with a Logitech F310 gamepad. The way we map the controls is that we use tank drive with the joysticks to control forwards, backwards, and rotation. For strafing we use the back triggers because they are analog. I believe they translate to twist on the flight sticks. Hope this helps.
Unread 17-01-2015, 13:06
You don't need any "elses"
max=fabs(s1);
if (fabs(s2)>max) max=fabs(s2);
if (fabs(s3)>max) max=fabs(s3);
if (fabs(s4)>max) max=fabs(s4);
if (max>1) {s1/=max; s2/=max; s3/=max; s4/=max;}
