Go to Post We can't turn off inspiration and recognition, development and learning with a switch. It is an on-going process. If it were not, there would be no need for CD except for 6 weeks out of the year. - JaneYoung [more]
View Poll Results: Is a three tote auto worth it? Accomplish-able?
3 tote auto is doable! 214 81.68%
3 tote auto is impossible! (to hard to be worth doing.) 48 18.32%
Voters: 262. You may not vote on this poll
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 09-01-2015, 02:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: 3 tote auto probability poll
There will be more than one game in which the maximum amount of autonomous points is scored. That is all.
Unread 09-01-2015, 08:22
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Originally Posted by mbshark View Post
Nothing is impossible
It just takes longer
Unread 09-01-2015, 08:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The obvious way to make sure the CONTAINERS are out of the way as you collect TOTES, is to also collect all three CONTAINERS before your robot heads over to the AUTONOMOUS ZONE.
Unread 09-01-2015, 08:36
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Rare week one, common by week five.
Unread 09-01-2015, 10:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
A 3 tote stack is easy. As a captain, pick a partner who can get the 2 RB's out of the way. Or demonstrate on the practice field that you can get the 3 tote stack if a partner gets the 2 RB's out of the way.
Unread 09-01-2015, 10:12
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I told my subteam that I'm not going to the competitions if we don't do it.
Unread 09-01-2015, 10:18
wajirock's Avatar
wajirock wajirock is offline
Safety General
AKA: Mohammed W.
wajirock has a spectacular aura aboutwajirock has a spectacular aura about
Creating a stacked tote set in auto by yourself seems fairly feasible. Since all three auto totes are in the same position in every math, you could have your robot strafe left or right and it picks up the totes when it detects the reflective tape. Creating a tote seems much more difficult and is worth far less points.
Unread 09-01-2015, 10:40
wesbass23 wesbass23 is offline
FRC #1732 (Hilltopper Robotics)
wesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud of
I noticed you guys are attending Wisconsin this year, maybe you should avoid perfecting a 3 tote autonomous until after Wisconsin
2014 Wisconsin Regional Winners with 2481 and 2202
2014 Midwest Regional Finalists with 2338 and 3936
2014 Midwest RCA Winner
2013 Wisconsin Regional Winner with 111 and 2338
2013 MARC Winners with 1718 and 1023
2012 Boilermaker RCA Winner
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
What I foresee on einstein: robot one does a 3 tote autonomous, the other two robots stack up 3 gray totes on the step, and all 3 robots getting the points for being in the autonomous zone as well.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 09-01-2015, 10:53
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
I actually don't see this as being too hard depending on how you carry the totes.
One example would be to start next to t1 between the tote and center step.
Pick up and place on TOP of the bot.
Roll in front of t2, index t1 up and pick up t2.
Roll to t3, index t1/t2 up and pick up t3.
If you pick up from the side of the bot you don't have to worry about going around anything.
I think a lot of teams will actually find fairly simple ways to get these points.
Unread 09-01-2015, 11:06
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
At Einstein, I would expect one robot doing the 3 tote auton, while the other two are trying to get all of the recycling containers on the step.
At top levels of play, getting 3 of the four recycling containers from the step, will pretty much ensure your victory.
Unread 09-01-2015, 11:07
barn34's Avatar
barn34 barn34 is offline
Isn't this how Skynet got started?
AKA: William Barnickel
FRC #2481 (Roboteers)
barn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond repute
you and I have very different visions of what we foresee on einstein.
1 robot 3 tote stack (brings 1 bin with them)
1 robot grabs 2 bins from step (bring second with them back to auto zone)
- keep in mind, the robots grabbing from the step will basically be racing against the opposite alliance trying to do essentially the exact same thing...
2016 Einstein Field WORLD CHAMPIONS & Carver Sub-Division Winner (330 & 120 & 1086)
2016 Smoky Mountains Regional Winner (3824 & 4740)
2016 Central Illinois Regional Winner (876 & 2220)
2015 Central Illinois Regional Winner (1756 & 2220)
2015 Rock City Regional Winner (2451 & 1625)
2014 Einstein Field Semi-Finalist & Galileo Division Winner (67 & 973 & 2363)
2014 Wisconsin Regional Winner (1732 & 2202)
--- Industrial Design Award (2010, 2015) ------ Innovation in Control Award (2013, 2014, 2016) ---
--- Quality Award (2015) ---------- Creativity Award (2014) ---------- Visualization Award (2009) ---
Unread 09-01-2015, 11:19
Programming Mentor
Really? it sounds almost exactly the same, except I did not have the tote stacker grabbing a recycling container for good measure -- which is a very good idea, as I agree the whole match is largely about the recycling containers on the step and it will be interesting to the inevitable autonomous tug of war.
EDIT: oops I thought you were replying to me -- oops again.
Unread 09-01-2015, 11:29
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
Personally, I think that it is possible. Our team started working on vision code on the way back from Kickoff, and we have code ready to test before the robot drives. We will be putting together our base Saturday, and programming can start working on auto before we even have a device to grab the totes. As long as teams manage their priorities and make best use of their time, I see this happening plenty.
ORB Haow!
Unread 09-01-2015, 11:34
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Originally Posted by themccannman View Post
Absolutely, I'm going to be surprised if you don't see at least one three tote auto at every regional.
I agree. I'll even put odds on somewhere out there, there is a team that will do a 3 tote stack and collect some containers along the way.
