Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
Unread 07-01-2015, 11:06
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Vaccum System
My team is seriously looking at the use of a vaccum cup on our robot this year but I will not go into detail exactly how. After research we know we can use a COTS vaccum pump simply retrofitted with a FIRST legal motor. Our question is there is no rules we can find on storing a vaccum on the robot. We know we can do it but want to know if it is FIRST legal or not. Lastly can we use regular pneumatic solonoids on a vaccum system in the same way we would use then in a pneumatic system.
Unread 07-01-2015, 14:38
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Vaccum System
In 2010 we used a shop vac, impeller was driven by a cim, used belts to increase speed about 4 times. Stuck onto the soccer ball very well.
Unread 07-01-2015, 14:51
t.selfors t.selfors is offline
AKA: Tim Selfors
FRC #1259 (Paradigm Shift)
Team Role: CAD
t.selfors is an unknown quantity at this point
Re: Vaccum System
R66: The following devices are not considered pneumatic devices and are not subject to pneumatic rules (though they must satisfy all other rules):
A. a device that creates a vacuum
B. closed-loop COTS pneumatic (gas) shocks
C. air-filled (pneumatic) wheels
Unread 07-01-2015, 15:10
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Vaccum System
Is it easier to store vacuum or just generate what you need when you need it?
I'm not sure if a solenoid would work but it's worth a try. I know most require a minimum pressure to function properly, but a vacuum would achieve the same thing if plumbed in reverse.
We used a vacuum pump in 2013 to pick up frisbees. We had to be pretty darn precise with placing the manipulator though. But ours was from a Food Saver so it was pretty minimal amount of vacuum.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-01-2015, 18:26
Michael U Michael U is offline
Programmer
FRC #2980
Michael U is an unknown quantity at this point
Re: Vaccum System
We, team 2980, used a ventrui suction device from Piab. It worked well for flat objects although it fell flat when we tried to use it to pick up the fabric covered balls (should have seen that coming). It runs well at 22 psi and can be reliably controlled by a solenoid. Just in case you were looking for alternatives.
Last edited by Michael U : 07-01-2015 at 18:27. Reason: Addition of helpful content.
Unread 07-01-2015, 20:04
mac mac is offline
AKA: Thomas (just give me a crabcake)McCubbin
FRC #0686 (Bovine Intervention/Jagbots)
mac is a jewel in the roughmac is a jewel in the roughmac is a jewel in the roughmac is a jewel in the rough
Cool Re: Vaccum System
Hi Doc. I've never seen or heard of anyone doing this. Rules should be Ok. Is this a one time shot for usage. Or do you have multi bottles? One of are mentors on team 686 took a bath room fan and turned it into a Ventura. It worked great picking up Frisbees. The students did not use it. It was to slow. Make it a great day.
Thomas McCubbin
Mentor and Volunteer since 2005
Unread 07-01-2015, 20:21
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: Vaccum System
The Fire Bears 2846 used a vaccum system last year. The Blue Alliance
It was incredibly cool. I question the necessity, and functionality of a vaccum system, but if you can pull it off more power to you.
Unread 07-01-2015, 20:39
ice.berg's Avatar
ice.berg ice.berg is offline
Strategy Mentor & Drive Team Coach
AKA: Alex Bergal
ice.berg has a spectacular aura aboutice.berg has a spectacular aura about
Re: Vaccum System
Dont forget about a venturi vacuum system. You can utilize pressurized air (which you may already have on your robot) to generate a vacuum.
TEAM 2512 DULUTH EAST DAREDEVILS
'12-'15: Strategy and Build Mentor
'15 Hopper Division Champions and Einstein Finalists thanks 987, 2826, 4265
'15 Minnesota State Champions thanks 3130 and 4215
'15 Northern Lights Chairmans Winner and Regional Finalists & Central Illinois Regional Finalists
'10-'11:Build Captain
'13 Midwest Champion '12 North Star Champion '11 Lake Superior Champion
Website Facebook Twitter Youtube Flickr
Unread 08-01-2015, 20:15
Nesquik Nesquik is offline
FRC #3374
Nesquik is an unknown quantity at this point
Re: Vaccum System
So are any certain vacuums considered illegal?
Unread 09-01-2015, 08:52
nHoude's Avatar
nHoude nHoude is offline
Robot Enthusiast
AKA: Nathan H
FRC #3467 (Windham Windup)
Team Role: Electrical
nHoude is an unknown quantity at this point
Re: Vaccum System
Yes and no. The vacuum itself is not illegal, but usually the motor powering it is. If you would like to to use a vacuum, you need to look up the specs of the motor in the vacuum and replace the motor with a similar FIRST legal motor.
For more information on what motors you can use please read R18 (under 4.7 Motors & Actuators).
Game Rules Link
https://rps01.usfirst.org/frc/manual...GameManual.pdf
FIRST Motors Specs
https://rps01.usfirst.org/frc/manual...nformation.pdf
Unread 09-01-2015, 10:41
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
Re: Vaccum System
You could also do what we did in 2004, and make your own vacuum pump. All you need is a motor and a pneumatic cylinder. As far as I know this would be legal under this year's rules, but there may be something in the manual I missed. (Pro Tip: Even if your frame is welded box aluminum, don't try to use it as an accumulator.)
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
