Go to Post Well, I know that I could crash the robot into a large object with even greater precision... but if you mean what could the kids do with it... yeah, they'd probably accomplish something creative and useful! - dtengineering [more]
Unread 09-01-2015, 12:01
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
R6
R6 says that the game pieces have to be easily and safely removable from the robot, but does not give us any explanation to what is easy. The safe part is easy to understand but is also subjective.
Example let's say a team uses a clamping mechanism to grab the totes and or cans using pneumatics, would it be considered "easy" to simply empty the air tanks, or maybe pulling a pin at one of the mechanisms pivot points?
Unread 09-01-2015, 12:09
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: R6
Generally, yes. The intent is to make sure it doesn't delay match cycle time.
Viva Olancho!
Unread 09-01-2015, 12:12
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: R6
In my opinion and experience, that would be considered easy. I have no ruling authority.
Field Reset crews are instructed to not touch the robots and to wait for teams to remove game pieces.
The inspector will check that you can remove the items as part of your inspection. They will evaluate it at that time to determine if it is easy and safe. The field staff will not take issue with it unless you take a long time and it delays the field reset. Remember that you are not allowed to tether after the match to release the game piece.
Unread 09-01-2015, 12:16
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: R6
The G11 blue box is what should inform your opinion on this. Yellow card for significant repeated delays to field reset. The blue box suggests you should be able to clear the field in less than 60 seconds after you're let on. As long as the dump valve is accessible, you should be able to do a dump and open a mechanism in much less than 60 seconds.
Unread 09-01-2015, 14:18
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: R6
As others have said, we're looking for safe and quick removal so we can avoid delaying match reset. Emptying air would be perfectly acceptable, as would any sort of quick manual manipulation of your robot mechanisms. While the blue box says 60 seconds, I personally try to Design for a max of 15 seconds.
2016: Lake Superior WFFA
Unread 09-01-2015, 15:09
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: R6
Related question:
Assume you are programming in labview and have said tote clamping mechanism. If you program your end.vi to leave the gripper open, at the end of the match will the gripper be open?
Unread 09-01-2015, 19:44
Re: R6
Originally Posted by Conor Ryan View Post
Related question:
Finish.vi never runs during normal operation. You will either have to open the gripper explicitly while the robot is still enabled, or use a single-acting pneumatic solenoid that automatically opens the gripper when deactivated.
