Go to Post Wow. Just wow. Never did I think the mentor built robot debate would make it on to a tv show. - ASD20 [more]
Unread 09-01-2015, 12:26
wendells's Avatar
wendells wendells is offline
FRC #2185 (RAMAZOIDZ)
wendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to all
sysProps.xml deosn't exist C++
When I am trying to send my code to the RoboRio, I get this error:
wpilib\cpp\current\ant\build.xml:117: Getting Started\sysProps.xml doesn't exist
When I check the CDT console for the build, it does not give me any errors.
Any suggestions?
Unread 09-01-2015, 12:37
Re: sysProps.xml deosn't exist C++
Did you image the roborio to the v23 image?
Unread 09-01-2015, 15:45
Manu Cherthedat Manu Cherthedat is offline
FRC #2185
Manu Cherthedat is an unknown quantity at this point
That worked, thanks.
Unread 25-03-2015, 15:13
twiggzee twiggzee is offline
FRC #3502 (Octo-(PI)-Rates)
twiggzee is an unknown quantity at this point
I'm getting the same error except I'm using Java. I checked to make sure our roboRIO is imaged to v23 and it was. Just for kicks, I re-imaged it anyways and it's still not working. Anybody have any ideas?
Here's what shows up in the Eclipse console:
Buildfile: C:\Users\chanw\workspace\Test\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\chanw\workspace\Test\build
[delete] Deleting directory C:\Users\chanw\workspace\Test\dist
compile:
[mkdir] Created dir: C:\Users\chanw\workspace\Test\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\chanw/wpilib/java/current/lib/WPILib.jar:C:\Users\chanw/wpilib/java/current/lib/NetworkTables.jar to build
[javac] Compiling 1 source file to C:\Users\chanw\workspace\Test\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\chanw\workspace\Test\dist
[mkdir] Created dir: C:\Users\chanw\workspace\Test\build\jars
[echo] [athena-jar] Copying jars from C:\Users\chanw/wpilib/java/current/lib/WPILib.jar:C:\Users\chanw/wpilib/java/current/lib/NetworkTables.jar to build/jars.
[copy] Copying 2 files to C:\Users\chanw\workspace\Test\build\jars
[jar] Building jar: C:\Users\chanw\workspace\Test\dist\FRCUserProgram. jar
get-target-ip:
[echo] Trying Target: roboRIO-3502.local
[echo] roboRIO not found via mDNS, falling back to static USB
[echo] roboRIO not found via USB, falling back to static address of 10.35.2.2
[echo] roboRIO found via Ethernet static
dependencies:
BUILD FAILED
C:\Users\chanw\wpilib\java\current\ant\build.xml:2 25: C:\Users\chanw\workspace\Test\sysProps.xml doesn't exist
Total time: 21 seconds
Wendy
Team 3502
