Go to Post At the competitions you can look like an idiot and nobody cares, that makes me happy... - Laura 1547 [more]
Unread 09-01-2015, 16:15
thetonio96 thetonio96 is offline
FRC #4635 (Eugenio)
thetonio96 is an unknown quantity at this point
Driver Station Voltage Burnout
Does someone know what Voltage Burnout message mean on the new Driver Station 2015?
Unread 09-01-2015, 16:21
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Driver Station Voltage Burnout
Assuming it says "brownout" and not "burnout", at some point, the RoboRIO input voltage was below ~7 volts.
Unread 13-01-2015, 22:43
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
I had this occur when stress testing our motors and control system.
A brownout occurs when it goes below roughly seven(?) volts and has a high risk of crashing your system and dropping the roboRIO. If you want to check this out, make your CIM motors reverse polarities very quickly and you'll see what I mean.
Unread 13-01-2015, 23:39
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
We had some interesting experiences with the beta hardware when we were testing the brownout characteristics - it's worth it to try to get a brownout (put in a low battery, push a wall or something) to see what drops out first. Also, if your robot design raises the possibility of a brownout (if you have a lot of motors pulling a lot of power), think about what will happen if a brownout does occur - the solenoids do some weird things, which could potentially be unsafe.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 30-01-2015, 12:15
GatorRobotics GatorRobotics is offline
FRC #3750
GatorRobotics is an unknown quantity at this point
Our Driver Station is showing Voltage Brownout, and we can't figure out what is causing it. We have disconnected everything from the power distribution except for the RoboRIO, and still get the error. Has anyone had this problem? If so, any remedies?
Unread 30-01-2015, 12:16
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
What is the driver station reporting the battery voltage as?
Unread 30-01-2015, 12:26
Possible causes:
  • Low battery (test with meter or use Driver Station readout)
  • Poor connections between the battery and the PDP (test with meter)
  • Heavy draw or short on circuit off PDP (pull breakers)
On the right of the Driver Station is a button "Logs..."
Click on it and you will be able to browse past data logs made while your robot was running.
One of the plotted lines is your battery voltage and orange marks at the top show when Battery Brownouts occur.
You can correlate the dips in battery voltage to the occurrence of brownouts.
RoboRIO Brownout and Understanding Current Draw
Unread 30-01-2015, 14:16
FRC #3750
23.+ is the voltage showing on the DS. I think we may have figured it out. We had the RoboRIO connected to a 24V output on the Power Distribution Board, we switched it to a 12V and it works. Small oversight on our part.
Unread 30-01-2015, 14:21
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Addison4300 is on a distinguished road
This happened to us. we were driving tank style and had one set of wheels going forward and the other going backwards. we were using the regular basic wheels. the strain from the friction of the floor was too much and cause us many brownouts while turning. so basically what i'm saying is too much strain on the motor will cause it.
Unread 30-01-2015, 14:25
cgmv123's Avatar
AKA: Max Vrany
You're using the old PDB? The new PDP doesn't have a 24 volt supply.
