Go to Post I'm not sure I like this: corn dogs, cheesecake and lard. - Tom Ore [more]
Unread 09-01-2015, 20:57
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
Re: SmartDashboard not connecting to robot.
Might as well highjack this instead of making a new thread for a tiny question and its related to SmartDashboard.
If I have a display() method that just puts values on the Dashboard, ex:
public void display(){
		SmartDashboard.putNumber("FrontLeft  PWM:", Robot.eboard.frontLeftSlot);
		SmartDashboard.putNumber("BackLeft   PWM:", Robot.eboard.backLeftSlot);
		SmartDashboard.putNumber("FrontRight PWM:", Robot.eboard.frontRightSlot);
		SmartDashboard.putNumber("BackRight  PWM:", Robot.eboard.backLeftSlot);
Do I need to constantly call that method throughout teleopPeriodic()? Or do I only need to call it once during teleopInit()? In other words, do I have to update Dashboard manually, or will it update automatically as time goes on?
ps i understand the pwm slots sure well aren't going to change its just an example of a display method that is only temporary...
Unread 09-01-2015, 21:12
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Based on your code there, where you're putting a number, you'll need to call that regularly. If you put smarter things to the dashboard such as Commands, they update their status on their own.
Unread 09-01-2015, 21:19
jtrv's Avatar
github.com/jhtervay
AKA: Justin
what would an example of a command be?
if i put SmartDashboard.putNumber(encoder1.get()); will it auto update or is that a command?
Unread 09-01-2015, 21:21
WPILib Developer
FRC #0190
Commands are part of command-based programming, which is one of the WPILib-supported programming paradigms. See in the ScreenSteps here: http://wpilib.screenstepslive.com/s/...ed-programming.
Unread 09-01-2015, 21:23
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Oh, right. I always forget about Command based
thanks for your help ^^
