Go to Post A robot that does 60% of the tasks 100% of the time is better than a robot that does 100% of the tasks 60% of the time. - artdutra04 [more]
Unread 09-01-2015, 20:07
DoughBoy's Avatar
DoughBoy DoughBoy is offline
FRC #3336 (Zimanators)
Team Role: Tactician
DoughBoy can only hope to improve
The hook design
What is the advantages and the disadvantages of using the hook because we have so many advantages of using them but could not come up with any disadvantages so we will be able to work with them
Unread 09-01-2015, 20:11
Andrew3336 Andrew3336 is offline
FRC #3336
Andrew3336 is an unknown quantity at this point
Re: The hook design
Well. Using a hook will only allow you to pick up the tote from a certain angle, but if your hook is measured correctly then it may be more stable than using other systems.
You could also invest into the forklift idea, but there are still problems with that.
Disadvantages to the hook may be that there is a chance your hook will break.
Unread 09-01-2015, 20:46
Jean Tenca's Avatar
Jean Tenca Jean Tenca is offline
Head Mentor
AKA: "John"
FRC #4488 (Shockwave)
Jean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of light
Re: The hook design
When considering designs, it's important to think about how easy they are to use.
1) How much precision does it require? Try approaching the game piece from various angles.
2) Do you have to be a certain distance for it to work? Can you always easily guarantee the necessary distance for your system to work?
3) How easy is it to use if you're trying to use this design on the other side of the field (or half field this year) with other robots and game elements obstructing your drivers view?
There are lots of questions that need to be answered while analyzing a design. Hopefully these will help you get started
Team 4488 Head Mentor
2015: [Carson Division Finalists (World Championship)], [Finalists, Entrepreneurship Award (PNW District Championship)], [Winners, GP Award (CWU District)], [Winners, Engineering Excellence (Oregon City District)]
2014: [Galileo Division Finalists (World Championship)], [Finalists, Quality Award (PNW District Championship)], [Winners, Industrial Design (Wilsonville District)], [Winners, Chairman's (Oregon City District)]
2013: [Rookie All-Star (Curie Division)], [Highest Rookie Seed, Rookie All Star (Autodesk Oregon Regional)]
2006-2012: Mentored various teams in OR and WA
2005: Team 1510 captain, founding member
2002-2004: Team 955 student/captain, founding member
Unread 09-01-2015, 21:16
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
Re: The hook design
One thing I can think about is once you stack so many totes, even if you make a strong hook, what you are grabbing onto on the bottom box may not be able to handle that load and will break.
Unread 09-01-2015, 21:36
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is online now
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Re: The hook design
GreenHorns have a simple design. https://www.youtube.com/watch?v=52pEIu1BHc8
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 09-01-2015, 23:38
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: The hook design
A hook with an alignment mechanism (Ri3D 1.0) is definitely a good way to go. The GreenHorns' hook mechanism was incredibly simple and effective, but in a 6 week build you should be able to build something that doesn't require as much driver precision. As for the bottom lip of the totes, I wouldn't factor their durability into your hook design. The totes are very durable and we had no problems.
Unread 09-01-2015, 23:59
Fawnhugs's Avatar
Fawnhugs Fawnhugs is offline
Maya
FRC #1339 (Angelbotics)
Fawnhugs is an unknown quantity at this point
Re: The hook design
Looking at the hook as far as I can tell it will work nicely. However the problem is the margin of error you give yourself with it. A hook like Ri3d could end up being a time sink if your drivers have a hard time positioning it (as we saw in the videos). Also if your strategy involves using upside down totes, a hook like GreenHorns would have to be modified.
Unread 10-01-2015, 00:06
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: The hook design
Thar be a sensor for that matey
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Last edited by IronicDeadBird : 10-01-2015 at 00:08. Reason: Totally didn't miss with the ctrl c+v
Unread 10-01-2015, 00:08
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Re: The hook design
Originally Posted by DoughBoy View Post
What are the advantages and the disadvantages of using the hook because we have so many advantages of using them but could not come up with any disadvantages so we will be able to work with them
Advantage: Simplicity
Disadvantage: must be perfectly lined up to work
Additionally, when carrying 3+ tote stacks, the stack will begin to sag forward, which could cause your container to fall off the top. This is really apparent in some of the later Ri3D vids.
Lastly, if not designed correctly, a hook design can/will damage the handles of the totes.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 10-01-2015, 00:19
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Re: The hook design
That's the beauty of it. It's a decent design that can easily be implemented. Getting it to work efficiently and effectively is the trick.
The hook mechanism is capable of flipping over totes but as you said it's a time sink. I'd like to think a driver could get extremely efficient with the current design, but you can only be so effective with 1 non-drive motor and 1 pneumatic cylinder.
I believe the design that we put out there can be easily modified in a way that makes it an effective robot, which is capable of getting to the playoffs.
Unread 10-01-2015, 09:45
DoughBoy's Avatar
Re: The hook design
Thank you to all the teams and mentors that have responded to this I really appreciate your inputs and ideas and our team while put in consideration to the ideas you have given us. We appreciate it very much.
Unread 10-01-2015, 14:15
Nathan Readous Nathan Readous is offline
FRC #3398
Nathan Readous is an unknown quantity at this point
Smile Re: The hook design
But other than many of the disadvantages to the hook theory it has many advantages to it to.
Unread 10-01-2015, 17:24
Tammyo Tammyo is offline
FRC #1261
Tammyo is an unknown quantity at this point
Re: The hook design
A disadvantage of a hook design may be that it would be hard to line up with a tote. Also, when you lift the tote with the hook the tote would not lift parallel to the robot, because you do not have enough points attached to the tote. This would result in unequal weight on your robot, risking your robot to tip.
I suggest you create a mechanism that is central to your robot's weight.
