Go to Post I need someone to kick me out...unfortunately that would have to be me... - Mark McLeod [more]
Unread 10-01-2015, 00:09
fireXtract fireXtract is offline
MegaHertz_Lux
FRC #2847 (Mega Hertz)
fireXtract is an unknown quantity at this point
robot.Triggers
It seems that the template for the command based robot spawns a subdirectory called triggers. Along with this when you use the new>other dialog there is a trigger option alongside the command and subsystem options. Has anyone played with this, and what is its use? I see no subcategory on my copy of the WPIlibs.
Unread 10-01-2015, 00:54
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: robot.Triggers
Its not exactly the same but you can check this thread, its talking about the new threads http://www.chiefdelphi.com/forums/sh...d.php?t=132118
Unread 12-01-2015, 18:08
MegaHertz_Lux
Re: robot.Triggers
Thanks, the gist of it is that anything that isn't involved with a Joystick event can be used with Triggers. If I understood the links properly.
