Go to Post I personally think that everybody on the team is important. No matter what, every single student, mentor, teacher put their effort all year long to get the team going. So in my opinion, Credit goes to everyone. - Arefin Bari [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 10-01-2015, 08:05
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We mounted mecanum wheels on our bot with 4 nanos and with heavy modification.
Unread 11-01-2015, 09:02
skottmorris's Avatar
skottmorris skottmorris is offline
FRC #4909 (Bionics)
skottmorris is a jewel in the roughskottmorris is a jewel in the roughskottmorris is a jewel in the roughskottmorris is a jewel in the rough
Re: Mecanum on kop chassis
This is the plan for our robot, mounting the TB Nano's on the AM14U2 with a modified width and length to make sure the mecanum wheels are located in the required square pattern, 90 degrees from each other. Using the closest holes in the chassis is giving us a pretty small drive base, but with some counter weights, should be okay.
This will be our first endeavor with mecanum wheels, so we're hoping this works out for us.
Unread 11-01-2015, 10:07
Originally Posted by skottmorris View Post
...with a modified width and length to make sure the mecanum wheels are located in the required square pattern, 90 degrees from each other.
Why do you say square is required?
Unread 11-01-2015, 16:10
mklinker's Avatar
mklinker mklinker is offline
Coach FRC4485
AKA: Mike Klinker
FRC #4485 (Tribe Tech Robotics)
mklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to behold
If not square what code adjustments would need to be made?
Mike Klinker Mentor, Tribe Tech Robotics FRC 4485
2016 Walker Warren District Semi-Finalist
2015 Indiana District Championship Semi-Finalist, Purdue District Quarter Finalist, Kokomo District Quarter Finalist, R2OC Finalist
2014 Boilermaker Regional Quarter Finalist
Unread 11-01-2015, 16:40
It depends on your driver interface.
If you are giving the driver control of Y,X,and rotate, then no code adjustments would be necessary.
If you have pre-programmed routines in the driver interface (or in autonomous) which depend on commanding specific rotation rates relative to translation commands, then you should scale the rotate command (in radians per second) by a factor K=(wheelbase+trackwidth)/2 as shown on page7 of this document or page19 of this one.
Unread 11-01-2015, 19:15
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Can you use a toughbox mini's to use mecanum wheels on the KOP chassis?
Unread 11-01-2015, 21:13
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
Yes, my team is able to do direct drive to the mecanum wheels. But, it involves using a second chassis ontop of the first one. Or, mounting braces that extend from the top of the base.
Unread 11-01-2015, 21:41
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
We've not yet tried a "mecanum" drive, but I have read that the wheels should be mounted such that the rollers form an "X" when viewed from the top or bottom. Am I misinterpreting this CAD drawing?
Unread 11-01-2015, 21:46
Maybe it's a bottom view?
Unread 11-01-2015, 21:50
markmcgary's Avatar
Software Mentor
I believe that even looking up at that, it's not going to make an "X".
Unread 11-01-2015, 21:52
If it makes an "O" when viewed from the bottom, it will make an "X" when viewed from the top.
http://www.chiefdelphi.com/forums/sh...3&postcount=28
Unread 11-01-2015, 22:05
markmcgary's Avatar
Software Mentor
It's not supposed to make an "X" when viewed from the bottom.
LOL. Now, I'm embarrassed. Of course, Ether, you are correct. Never having handled one of these mecanum wheels, I had to perform a more detailed mental exercise to visualize the roller angles properly. Note to self: The roller angle forms an "X", only when viewed from the top. Thanks!
Unread 11-01-2015, 22:16
markmcgary's Avatar
Software Mentor
OK, I admitted to not knowing my "X"s and "O"s. But, going back to the original CAD rendering, that does appear to be a 2015 KOP drive base looking down from the top.
Unread 11-01-2015, 22:44
Sperkowsky's Avatar
Nope
Unread 14-01-2015, 05:02
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
Andy Mark just released this 6" Mecanum upgrade kit for the AM14U2. IMHO, the 6.7:1 gearbox ratio is too low for this years game.
http://www.andymark.com/product-p/am-14u2-Mk6.htm
"Genius is 1% inspiration, 99% perspiration"~Thomas Alva Edison
2016 Hawaii Regional Winners
