Go to Post ...because "someone on ChiefDelphi said so," doesn't fly when your robot can't pass inspection. - Madison [more]
Unread 09-01-2015, 21:27
16guevaran 16guevaran is offline
AKA: Nate Guevara
FRC #5113 (Combutible Lemons)
Team Role: Student
16guevaran is an unknown quantity at this point
Lightbulb Tote Grapping Strategy
I have a concept for grabbing totes and bins and I want to hear what everyone else has to say about. If you have any comments, questions, ideas, or any other advice please comment. Any advice will be appreciated.
My idea is to use a piston connected to a motor via a chain and some suction cups with tubes connected to the piston. When the suction cups are pressed up against the side of the tote or bin, you turn the motor on, so it pulls the chain in, making it pull the piston along with it creating a vacuum. Since the other end of the piston is connected to a tube which leads to the suction cup, the created vacuum will pull on the side of the tote or bin holding it in place so that it can be picked up and moved around. There will be two of these vacuum suction cups on either side of the tote/bin so that the tote/bin will be stable when picked up, and will not fall off. This can make stacking totes easier because there is nothing underneath of the crate when the robot grabs it, so the robot can place the tote directly on top of another, making it less likely that totes on top will fall off.
Unread 09-01-2015, 22:16
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Tote Grapping Strategy
https://www.youtube.com/watch?v=1Mf662yER3c
2014 IRI Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship Winners (Thanks 2052, 4778)
2014 Archimedes Quaterfinalists (Thanks 399, 2056, 2834)
2013 Minnesota State Championship Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
Unread 09-01-2015, 22:18
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
I am not your team engineer (ianyte), but:
You could get that to work I think sure - it would be a lot like those mechanical suction cups you use to mount go-pros and GPS. The major challenge will be making sure you get a good initial seal with the suction cups. If any air leaks in as you draw the cylinder back, you'll lose any vacuum you created, and you'll reach the end of the stroke without any grip on the tote. This will be double challenging given the totes have textured, corrugated sides. Maybe if you had some mechanical way to press the seals tight before drawing the vacuum.
Also, as bvisness points out, there are easier ways to lift the sides of a (right side up) tote.
Unread 10-01-2015, 09:21
The Devinator The Devinator is offline
Meatball Slayer
AKA: Devin L.
FRC #5113 (Combustible Lemons)
The Devinator is an unknown quantity at this point
This is simply bologna
Unread 10-01-2015, 09:37
hokman18 hokman18 is offline
AKA: Kevin H.
Team Role: Electrical
hokman18 is an unknown quantity at this point
I agree with the devinator
Unread 10-01-2015, 18:29
NH Swag's Avatar
NH Swag NH Swag is offline
Representin' the Shire
AKA: Timothy Rice
FRC #1831 (Gilford Screaming Eagles)
NH Swag is an unknown quantity at this point
Personally, I think that using suction cups will prove promising on the totes. It wouldn't matter if a tote was upside down or right side up. But I foresee them being more difficult on the bins, because they are curved and somewhat flexible. With all that in mind, creating a bot that uses suction cups would easily win you the Xerox Creativity Award. It is one of those things that few teams would see to fruition.
Unread 10-01-2015, 18:54
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
https://www.facebook.com/video.php?v...27568399870724
2016: FRC 865 Mentor
Unread 10-01-2015, 22:40
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Do not use suction cups to try to pick up the totes or cans - you will thank yourself later.
, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 11-01-2015, 01:15
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
, Bryan
Yes, listen to one of the original teams, its probably a good idea.
While this is indeed an interesting (and functional if done right) idea, there are far more effective ways to manipulate a tote/can. Do I hear scissor lift anyone? (Just kidding)
Unread 11-01-2015, 02:02
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Originally Posted by mman1506 View Post
Now that is a manipulator....Bring your own Semi-Truck Scales...Watch him go 3D Print it to lighten it up and get it to actually work. What is the vaccuum pump on that BTW? We had fun w/ a leg lamp too, but, they could actually play the game with it also.
He'll be the one to figure out how to turn over every one of those flipped upside down Grey Totes easily and be able to push all the totes to you to stack, and cap the stack in Auto, and everyone will be clammering for him to join their Alliance...Lol.
Unread 11-01-2015, 02:14
EricH EricH is online now
There might actually be a simpler method of generating that suction, if you do indeed decide to go that route. Assuming you're already using pneumatics, replace the motor/chain with a pneumatic cylinder that will be fully retracted(or extended, depending which port you use) when suction is being applied. Ideally, you'd have a small(er)-bore cylinder pulling a large(r)-bore one with one port set vented to the atmosphere.
This method has been used before, with some success, on exercise balls. Whether it'll generate enough vacuum on totes is left as an exercise for whoever wants to experiment (I happen to not know the answer either, though I suspect it would).
Unread 11-01-2015, 09:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
One of our students spent an hour with a hack saw and a chunk of plywood, and made a neat gizmo that fits the side of a tote and lets us lift it up. No moving parts. It's not very impressive looking. But it works.
Unread 11-01-2015, 11:50
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
I agree with having nothing under the totes, that certainly makes stacking easier. Our team is designing a mechanism similar. In my opinion, however, this design seems rather complicated, or at least unreliable. Ideally, a robot should have something that works the same every time. I speak from experience, due to the massive ice storm that affected part shipments for our team last season, our device for manipulating the game piece last year was rather shoddy and didn't work consistently. Don't let me spoil your ideas, however, because everything can be worked into something perfect with enough time.
ORB Haow!
Unread 11-01-2015, 11:56
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Very clever OP but aren't you overlooking the fact that the totes have handles. My advice is KISS.
Unread 12-01-2015, 00:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Could it work? Sure, if you grab the flat, smooth parts of the bin and no one man-handled that tote in any of its previous matches to leave a gouge. If you do decide to proceed down this path, make a prototype quickly, because this is one of those "you don't know what you don't know" problems, and the only way to find out what you don't know is through fiddling with it.
