Go to Post In my opinion, if it can light a fire in your heart to burn with passion, and you can maintain that fine line between passionate and crazy; then go for it. Power to Passion. - RKElectricalman [more]
Unread 10-01-2015, 13:09
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
PDP LEDs not lighting
Hello, we are getting started with the new control system. Things seem to be working OK with the power subsystem, yet the STAT and COMM LEDs are not doing anything at all. The manual says that means "Device is NOT powered". We have the termination jumper set to ON and at the end of the PDP is at the end of the CAN bus.
When we power on the main breaker the bridge and roborio power up, code can be deployed, and motor controllers power (in idle). So i think the PDP is functioning right. It just seems light a status issue.
Is there a firmware update that we need to do to the PDP, or do you think our PDP is just bad out of the box? I've only seen mention of PDP firmware updates in Beta tester documentation.
Thanks
