Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Unread 10-01-2015, 11:31
asnell16 asnell16 is offline
FRC #3323
asnell16 is an unknown quantity at this point
Unhappy My RoboRio needs a doctor
Hello I am a leader of Potential Energy team 3323 in NH. We received a RoboRio in our KOP this year. We then looked up the schematics for wiring it in and made a prototype board. the RoboRio is receiving 12v of power with a 10amp circuit breaker. This seems to be a sufficient amount of energy but when we turned it all on we waited about 30 seconds and then our status light came on. After that it flashed 2x repeatedly. Now we know this means something is wrong with the software so we are going to try re-imaging it. However, the power light refuses to go on. We are all very confused at how we are getting no power yet the status light works. Is this a problem of needing it re-imaged or what? All of our programmers and electrical members are confused as well as our mentors no one knows what could be wrong. If you have any suggestion as to how we may be able to get our power light to work we would be greatly appreciated.
Unread 10-01-2015, 11:56
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: My RoboRio needs a doctor
Call NI Support at 866-511-6285 between 1 PM CST and 7 PM CST on Monday.
Unread 10-01-2015, 12:07
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
1058 is in the same process right now. If we get it to work I will let you know so we can help you out.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 10-01-2015, 12:47
Qmcdonn Qmcdonn is offline
FRC #2374
Qmcdonn is an unknown quantity at this point
Did you make sure that you connected the PDP to the RoboRIO through CAN? I'm pretty sure that the PDP needs to be connected via CAN For it to work. Also make sure that you put the 10 and 20 amp fuses in the PDP.
Unread 10-01-2015, 13:32
FRC #3323
Yes we did make sure we also connected the PDP through the can ports though we don't know if it is necessary, and we did put the 10 and 20 amp fuses in.
Unread 10-01-2015, 13:34
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Originally Posted by asnell16 View Post
Turned it all on we waited about 30 seconds and then our status light came on. After that it flashed 2x repeatedly....However, the power light refuses to go on.
This sounds very odd indeed. Your power LED is not lit, yet the status LED is flashing? Sounds like you are in fact getting power, but the power LED may not be functioning properly.
Can you proceed with the SW update?
Unread 10-01-2015, 13:50
AKA: Chris Rake
no team (Athena)
And one more thing - is your power plug all the way seated in the roboRIO power socket and screwed down? Doesn't explain the power LED not on, but the status light should light up shortly after you apply power. The 30 second delay is suspicious.
Unread 10-01-2015, 13:55
FRC #3323
Possibly, currently we are re-imaging it and after that we will see if it still functions without the power LED. Also yes if was properly screwed in. The 30 second delay was for the first time we gave it power after that the status light came on almost immediately.
Unread 11-01-2015, 11:30
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
3323 did you guys get your RIO working? As far as I know our programming/electrical team had a smooth transition to the new system. Let us know if we can help you guys out.
1058 PVC Pirates 2016 - xxxx
Unread 11-01-2015, 11:34
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
I believe the 30 second delay when the roboRIO is first powered on is a POST (Power On Self Test.) You could always try checking the roboRIO user manual found on National Instruments' website.
ORB Haow!
Unread 11-01-2015, 11:49
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Have you wired the roborio up to one of the regular ports on the PDP with a 10 amp breaker, or the dedicated port for the roborio on the short side of the PDP with the 10 amp fuse provided with the PDP?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-01-2015, 12:42
FRC #3323
we have a member that was re imaging it but he left early last night. Our schools computers do not work for this so a laptop must be used we are trying to order a team laptop but until then we must rely on a member of programming to try to re-image it. They insist re-imaging it should fix all problems. If this doesn't work we will call support on Monday. Thank you everyone for your assistance in helping us figure this out.
Unread 11-01-2015, 12:53
EmileH's Avatar
EmileH EmileH is online now
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
In order for the RoboRIO to work you do not need to have it wired via CAN. The PDP can function fine without any can interfacing.
Also make SURE the 10 amp and 20 amp fuses are in their respective slots - the 20 amp fuse on the left giving power to the PCM and VRM, and the 10 amp fuse on the right for the RoboRIO power - see image below
The RoboRIO should be plugged into the CONTROLLER POWER slot with 18 - 22 wire guage.
Unread 11-01-2015, 12:57
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
You followed these directions right?
https://wpilib.screenstepslive.com/s/4485
Unread 11-01-2015, 15:06
FRC #3323
emileh3467,
We currently have wired it this way. When it did not work we tried connecting can as well. and it still didn't work.
Conor Ryan,
Yes we also followed these directions.
Our members just tried re-imaging the RoboRio and it still doesn't respond or work correctly. We will call for support Monday. Thank you to everyone that gave suggestions and advice.
