Go to Post I heartily applaud FIRST for finally reacting proactively to this ongoing problem. - Ether [more]
Unread 10-01-2015, 01:01
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Re: CAN Rules
And while I'm at it, do teams have any recommendations for connectors for the CAN wires?
We are likely to try out the new Talon SRX. They have wires for CAN. How should We connect the CAN wires together? What kind of connector would be good here?
We're considering PWM connectors, but they PWM connector notoriously do not lock.
Thanks for the ideas.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 10-01-2015, 02:05
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: CAN Rules
Posted this in another thread, but since you ask.. Hansen Hobbies sells 2-pin latching polarized PWM connectors. They are what we'll be using on our 2015 robot. http://www.hansenhobbies.com/product...nlpconnectors/
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 10-01-2015, 09:30
NabilHanke NabilHanke is offline
FRC #4646
NabilHanke is an unknown quantity at this point
Re: CAN Rules
The connectors form Hansen Hobbies are at a price premium. They are just Molex connectors - try digikey http://www.digikey.com/product-detai...2573-ND/134131
Also, electricity is color blind to insulation color. Twisting your pairs isn't absolutely critical on CAN, but not doing so will turn 2 minutes of laziness into two hours of hair pulling. CAN uses a differential signal: both will rest to the same voltage, then when signaling, CAN High gets pulled up a volt or two and CAN low gets pulled down a volt or two and they are compared against each other. If there is noise it'll effect them the same and that differential will remain intact. Good stuff.
Where you can find another opportunity to pull your hair out is loose connections on the CAN bus. It is a bus, all CAN High connections should be congruent with each other and all CAN Low connections likewise. If you have a bad connection in the middle, you'll lose not just the other half of devices, but the terminating resistor as well and the whole bus itself... well, in an ideal world. But fortunately theory and reality don't agree and sometimes you'll still have an intact bus.
BTW, I'd use WAGO lever locks for the motor controllers.
Unread 10-01-2015, 13:54
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: CAN Rules
Yeah, the green/yellow is helpful for other reasons.
-Makes robot inspection and troubleshooting easier.
-The colors are labeled on the roboRIO CAN connector
-The colors are present on the PDP/PCM Weidmuller connectors.
-The colors match the Talon SRX cable harness
It all adds up to a better CAN bus experience.
Very well put.
Unread 10-01-2015, 14:05
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: CAN Rules
What we did (temporarily) is just twist the ends together, then wrap with electrical tape. It lets you verify everything works, you can address each Talon, and drive it around.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 10-01-2015, 14:49
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Re: CAN Rules
Originally Posted by stinglikeabee View Post
If you want to twist your own cable...
https://www.youtube.com/watch?v=YAquFszYZ1k#t=75
Note: Please do NOT FORGET YOUR SAFETY GLASSES like the guys in the video did if twisting that wire w/ a drill. Sight is important!
