Go to Post Redfoo is actually a really awesome guy. He discussed the future of engineering and talked about C programming with our software team. - SM987 [more]
Unread 10-01-2015, 14:52
5339 5339 is offline
FRC #5914
Rookie Year: 2104
5339 is an unknown quantity at this point
Chassis
Last year as a rookie team we built the chassis to specs but had to use tank drive because the bot skipped and shuddered when turning. Shud we put the center drive wheel lower than the belt drive wheels if so how? Oblong the hole and shim it so it dont move?
Unread 10-01-2015, 14:57
Re: Chassis
Yes, the center wheel should be lower... IF you only use traction wheels. If I'm not mistaken, the KOP chassis has a dropped center hole. If it doesn't, I'd drill a new hole--turning a hole into a slot has a tendency to not end well if you need stuff to not move.
But there are other options. For example, you could pick up some omni wheels and put them on the "light" end of the drivebase, or on the corner spots. (Don't drop the center wheel for this configuration.) Or you could use a "wide" configuration (wheels on the short side of the chassis) which will give better turning.
Unread 10-01-2015, 14:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: Chassis
You can try putting omni wheels on the 4 corner wheels. That could fix it, because the omni rollers will allow the front and back to slide.
Unread 10-01-2015, 15:42
Thromgord's Avatar
Thromgord Thromgord is offline
The Warlord
FRC #3807 (The BlazerBots)
Team Role: Marketing
Thromgord has a spectacular aura aboutThromgord has a spectacular aura about
Re: Chassis
My thoughts precisely. The easiest but worst way of fixing this is to wrap electrical tape around the front and rear pair of wheels, like our team never has done*, because it causes a lack of overall traction while not really solving the problem.
*if you're wondering, we did this three years ago but don't want to admit it, as it's a poor solution.
...yep, going with Omni wheels is the best way to go.
