Go to Post ...and part of being Graciously Professional is knowing what your job is and how to perform the duties of it accurately. - jamie_1930 [more]
Unread 07-01-2015, 16:27
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
<R3> A. Robot Height
According to <R3>
The ROBOT must satisfy the following size constraints:
A. during a MATCH, the ROBOT height may not exceed 78 in.
Is this dimension relative to the floor or to the normalized lowest point of the robot.
For example, if a robot that was 78" tall drove over one of the scoring platforms. Would that robot be in violation of <R3>?
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 07-01-2015, 16:33
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: <R3> A. Robot Height
G22:
ROBOT height must not exceed 6 ft. 6 in. during the MATCH.
G22 Blue Box:
For reference, the height restriction matches the height of the ALLIANCE WALL. However, it is expected that ROBOT that are on a SCORING
PLATFORM may actually be slightly taller than the ALLIANCE WALL due to the elevation of the SCORING PLATFORM. This is permitted and
not a violation of G22.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 07-01-2015, 16:34
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
This is actually a question for G22, not R3. At the time of inspection, the robot will be sitting normally. So you could pass inspection that way. In fact, even if your robot has the Physical ability to extend higher, you can still pass R3 by claiming there are Software features that restrict the height.
G22 is the rule that will be enforced by the refs on the field, and specifies the penalties for violation. The blue box below it also specifies some examples of what they expect the refs to see and how the refs can make a quick judgement while on the field.
You would have to ask the Q&A TO get a more specific ruling than G22 provides.
2016: Lake Superior WFFA
Unread 07-01-2015, 16:39
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
I this may be worth a Q&A clarification, I was wondering the same thing, especially if it tips backwards while going over the ramp, that could put it's highest point much higher than 78"
Right now I am reading it as the ROBOT, per the glossary, is the "...electromechanical assembly..." itself which if it is built to not get taller than 78" there is no way you can rearrange it in space that will change how it is built, therefore how tall it is.
If I pick up my christmas tree no one is going to say the tree itself it taller now.
Edit: Yes, G22 blue box seems to confirm.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 07-01-2015, 16:44
Mentor, LRI, MN RPC
But if you pop a wheelie in your car, it may not fit under the overpass anymore! I think it's a valid question - are transient extensions above 78" caused by a change in orientation of the robot (but not a change in mechanism position) legal?
Unread 07-01-2015, 16:59
I think G22 is pretty clear, measured on a floor when the robot is on the floor. If you design causes the robot to tilt (by dropping a foot or wheeled plate) and during operation a part of your robot should approach or exceed the dimension, you will have to demonstrate that you limit this action in software or hardware, just as in previous years. Inspectors and refs will be watching and checking. I would bet the Q&A will respond that is your responsibility to insure no part of your robot extends above 78" while playing on the field, but please ask.
Unread 10-01-2015, 16:33
Gibbs's Avatar
Gibbs Gibbs is offline
Just a guy
FRC #2996 (Cougars gone Wired)
Team Role: Mascot
Gibbs is an unknown quantity at this point
Two questions. One, what kind of car are you driving? And two, what overpass are you driving under?
"Man who lives in glass house, should shower in basement."
-Confucius
Unread 11-01-2015, 02:48
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
The way they designed the Backstops (so that the tops are at exactly 78" above the scoring platforms), and allowed us to go up to that height and no further, makes it pretty easy to see from across the floor from each side of the field, where we can pretty much expect the Ref's to be positioned during matches I'd think. You hide the backstop top bars when driving on the carpet, they are going to be questioning you as you might be 2" high. Easy to check though if they just roll you up on an empty platform...That top of the top bar on the backstop should be equal to or above your robot when up there. You hide the bar, it may be tape measure & question time. Blue box pretty much covers it in both sections. Alliance wall height on the carpet, backstops on the platform, and transition from both is also covered. **No plain wheelies on the open carpet though.
(Of course I also saw 3 different robots strike the Truss last year too...1 with a huge "CLANG!" How did that happen? (They cleared when flat, but they were run into quite hard, it lifted one end quite high while they were still moving toward the truss, and it came back down at just the right spot and slapped the truss w/ their end wheels still a few inches off the floor, bounced of, then drove right under it).
My question is that the Crate Instructions are not out yet (usually found with the Admin. Manual), and according to all the recent shipping crates over the past few years all the crates had to be no more than 70" high (so they could be double stacked), including the 4 X 4's for forklifting, top & bottom (floor), of the crates. 70"-5"=65" High inside.
Now, How do you fit a 78" tall "Bagged Robot", into a 4' X ' 4' X approx 65" tall max. inside height crate without unbagging & taking it apart? Not even corner to corner on a diagonal fit if it is a ft wide or more. They must know what they are doing though.
Unread 11-01-2015, 02:55
Just to go back a bit, in 2007 the robots could be 6' tall in the starting box (under the condition that they be 100 lbs or less). At Kickoff, there was a "Jeopardy!" style Q&A, to which one of the question/answer pairs was "How do you fit a 6' tall robot into a 5' tall crate?" "Plan ahead."
