Go to Post FIRST is similar to real life in that nothing is perfect and you have to deal with the circumstances as they arise and make the best of it! - Sean_330 [more]
Unread 10-01-2015, 17:28
M.Kong-Sivert M.Kong-Sivert is offline
AKA: Mackenzie Kong-Sivert
FRC #2375 (Dragon Robotics)
M.Kong-Sivert is an unknown quantity at this point
Pneumatics
Our team has not used pneumatics on the robot since 2010, so nobody remembers how to program it. We were setting it up today, but it wouldn't work, and we can't figure out what went wrong. Does this program look right? Thank you.
Name:	mac_idea_code teleop.PNG
ID:	17797  Click image for larger version
Name:	mac_idea_code ptasks.PNG
ID:	17798  Click image for larger version
Name:	mac_idea_code begin.PNG
Unread 10-01-2015, 18:31
Re: Pneumatics
That uses button #2 on the game controller, not the trigger if that's what you were thinking "1" mapped to. The trigger would be index 0.
You can actually delete all the compressor code you have there.
Some of it is incorrectly placed, but it isn't explicitly necessary anymore with the roboRIO. If you Open a Solenoid, the compressor automatically gets created too.
Unread 10-01-2015, 23:55
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: Pneumatics
Just a couple of thengs here. No need for compressor code, that's automatically created and handled by the new pneumatics module this year. You can also be a boolean value directly into a "solenoid set", no need for the select. Hope I could help.
Unread 11-01-2015, 08:36
Re: Pneumatics
That only works for a single solenoid not for a double which the OP's code handles.
