Go to Post In my book the team building experience of the kids training the engineers in the operations on the field would be invaluable. It might not get a trophy but you win far more in the long run. - Wayne C. [more]
Unread 01-10-2015, 02:55 PM
BariSaxGuy's Avatar
BariSaxGuy BariSaxGuy is offline
FRC #5013 (Trobots)
BariSaxGuy is an unknown quantity at this point
Cameras allowed on the robot
Which cameras are permitted for use on the robot?
Unread 01-10-2015, 05:49 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Cameras allowed on the robot
Naturally, you can still use the Axis IP cameras from previous years. However, if you want to use a USB camera, you need to make sure that the camera is Linux UVC compatible. This means just about any Logitech USB web cam as well many others from different manufacturers.
You can go to: http://www.ideasonboard.org/uvc/ to get a listing of all of the UVC compatible devices.
On the couple of 'bots we've got running so far, we've been using the Logitect C920 hi-def camera because it does the H.264 encoding in the camera itself, which reduces the load on the RoboRio considerably. That camera is ~$79 at our local Bestbuy.
HTH,
Mike
Unread 01-10-2015, 07:10 PM
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Anyone know if this interfaces with the roboRIO?
http://www.andymark.com/product-p/am-3025.htm
We really only want a camera to send video back to the driver station so we can see even with tall stacks. Would this work for that?
Edit: Yes you can! http://www.chiefdelphi.com/forums/sh...soft+lifeca m
