Go to Post Engineering is a big, big type of fishing to teach. Inspiring kids to study it in college might be more practical. - connor.worley [more]
Unread 10-01-2015, 16:51
414cnewq 414cnewq is offline
FRC #3844 (Kentucky Wildbots)
414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of
Robot will not work.
After setting up the driver station (to the instructions), programming the router(no errors), and uploading the sample code from Eclipse to the roborio (successful compile of the "Getting Started" Java code), the driver station (error-free installation) connected to the robot only to be unable to drive it! The XBOX 360 controller is connecting (I was able to tell by the dashboard), but the robot didn't budge. Any idea as to why?
Unread 10-01-2015, 17:00
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
Re: Robot will not work.
Is the joystick in the correct channel on the driverstation? Should be channel 0 if you didn't change it in the code.
Unread 10-01-2015, 18:41
Did you install Java onto the roboRIO?
Installing Java 8 on the roboRIO using the FRC roboRIO Java Installer (Java only)
Driver Station Enabled?
Just askin'
Are the Driver Station's Communication and Robot Code indicators green?
Does the RIOlog show any errors?
Using Riolog to view console output
Unread 10-01-2015, 18:57
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
PWMs? Try flipping them around maybe. Talons and Jags should have a solid light when enabled. If they're flashing, then you might need to flip PWMs around.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 10-01-2015, 19:53
It is on the right channel in the code.
Unread 12-01-2015, 11:46
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
Probably shooting at straws but I saw on one of the Robot In 3 Days videos that even if you are not using CAN, it must be wired from the RoboRio to the PDB to make it all work.
Unread 12-01-2015, 16:17
The PWMs were the problem. Thanks!
