Go to Post What good will it do to have 10,000 teams who barely have a clue and are just scraping by versus 2,000 teams that are actually sustainable? - Cory [more]
Unread 10-01-2015, 18:40
toropov023 toropov023 is offline
FRC #5024
toropov023 is an unknown quantity at this point
Problems with Netbeans imports
Hello, I'm not familiar with Netbeans, as I prefer IntelliJ and I don't like Netbeans at all... Anyhow, I have a little problem with it. When I create a new template (extending IterativeRobot) and try to import the following classes:
  • import java.io.File;
  • import java.net.URL;
  • import java.net.URLClassLoader;
Netbeans cannot find them. I tried everything I could think of: reinstall the plugins, create normal Java project and write the same code (it actually worked fine in a normal Java project). Please help if you can.
Thanks.
Unread 10-01-2015, 19:15
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: Problems with Netbeans imports
Why are you using Netbeans? It's not a supported IDE for 2015.
You'd be better off using Eclipse and following the installation steps for WPILib on the screensteps webpage
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 10-01-2015, 19:37
FRC #5024
Right, I just thought of that myself, bye Netbeans...
