Go to Post The fact that although many of us disagree on specifics of how FIRST should conduct events, design a game, and facilitate as much fairness between teams as possible, in the end we still greatly enjoy each other's passion for FIRST and provide genuine respect for each other - Andy Baker [more]
Unread 10-01-2015, 19:19
Kyle_1881 Kyle_1881 is offline
FRC #3950 (Robo Gym)
Kyle_1881 is an unknown quantity at this point
Question about loading totes at the human player station.
Today we got to test out our field elements on carpet and we have found that totes don't land normal on the ground if the latch is simply opened with the tote resting on it. This is a trend we have seen in others tests as well. My question is if we could release the tote say 3 inches off the latch and open the door after we release it (in testing this made for a perfect landing every time if done correctly). By releasing the tote then opening the door G6 would not be violated (or would it). Any ideas? Also if you have done any testing with the totes and the human player station please let me know how your totes landed.
Here is a video of how totes normally land: http://youtu.be/Y1-3u9NEeO4?t=50s
Thanks! and Good Luck!
Unread 10-01-2015, 19:23
Re: Question about loading totes at the human player station.
If you're in contact with the door and the tote, it's a foul, -6 points. I fail to see how the tote won't slide to the door if you release it before opening the door, given the slick surface and steep angle.
Unread 10-01-2015, 19:43
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
As long as you let go of the Tote before reaching the handle you would be good. You just cannot contact both the Tote, and door handle at the same time is all. That would be really sad if those as built field chutes don't work that well.
You'd think they would be fairly well tested as a Human Game Element. Then again, they had to add bottom rods to the chains in the upper frisbee targets too.
Unread 10-01-2015, 20:18
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
My biggest concern with this system is that it appears when the door is opened the tote doesn't slide out. Pretty sure you can see that happen twice in the linked video above.
Then what do you do?
Looks like they pushed it out in the video.
We did a lot of testing with our home-made tote chute and the totes didn't slide all that well. Hopefully there is a good technique to repeatably get these totes through the wall.
Not to mention the tote "crashes and burns" once it exits the chute. Not exactly the way it worked in the FIRST field tutorial. Makes the landfill slightly more appealing.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 10-01-2015, 20:36
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
we built up our game pieces today and also had some problems with the totes tipping when they came out of the chute. What we found is that if you open the door all the way up(no contact with the tote), then just as the tote is about to fall out you drop the so that the bottom of the door drag on the tote for the last few inches then the tote will land flat every time.
Hope this helps
Unread 10-01-2015, 20:47
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Hope this helps
We saw the same effect.
Our station is the low cost wood design. The tote slides down a ramp surface of masonite, which is probably not the same as the plastic in an official station. Has anyone tried this with an official station?
Richard Wallace
since 2003
Unread 10-01-2015, 21:09
jagoldman jagoldman is offline
jagoldman
AKA: jagoldman
FRC #2972 (RC Dawson)
jagoldman is an unknown quantity at this point
Since there are three team on each alliance, that means you have more than one person who can operate those. With that in mind, one person can lift the gate while the other pushes the tote.
Unread 10-01-2015, 21:17
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
G5 doesn't make this a legal scenario.
Unread 10-01-2015, 21:46
LittleJoe's Avatar
LittleJoe LittleJoe is offline
Senior Media Captain RoboRiot 3418
AKA: Jonathan W
LittleJoe is an unknown quantity at this point
Hope this helps
This technique works very well and it also causes the tote to end up positioned (most of the time) in a perfect position to receive a 2nd tote right on top of the first. I had a streak of 3-4 drops where I sent the first out with this method and the second landed perfectly on top With practice it shouldn't take any longer then just lifting the door and letting it go.
Our station is the low cost wood design. The tote slides down a ramp surface of Masonite, which is probably not the same as the plastic in an official station. Has anyone tried this with an official station?
To answer your question we also used HDPE for the bottom of the slide.
Unread 10-01-2015, 22:54
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 has a spectacular aura aboutjimbo493 has a spectacular aura about
When we tried it at the half field at the GVSU kickoff in Grand Rapids, the totes consistently landed right side up, with only having to pull the lever up. I suppose you may have a construction issue.
Unread 10-01-2015, 22:56
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Hold on a minute this could also be a programming problem...
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
Unread 10-01-2015, 23:00
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
Almost certainly a programing problem
Unread 10-01-2015, 23:01
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
I told them not to let the programming team build the field.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
