Go to Post In FIRST, success = inspiration. - Daniel Brim [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-01-2015, 21:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 2015 KOP gear box binds up
We had the problem of one binding, and some students took it apart and put it back together again. All better now. My guess is there are several possible causes, and you need to figure out which it is. Make sure the case screws are not too tight, for example.
Unread 11-01-2015, 17:16
DonRotolo's Avatar
Back to humble
FRC #0832
I don't have a 2015 trans to look at, but in past years gears had a small shoulder on one side, at the hub. If assembles upside down (inside out?) it would cause binding.
The shoulder looks like a ring-shaped bump surrounding the hole in the gear, on one side of the gear only. It is not very tall and easily overlooked.
Unread 11-01-2015, 23:47
dradel's Avatar
dradel dradel is online now
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
we had this issue as well. this is what i found today. At first I thought the output shaft was contacting the input gear, so i put it in the lathe and spun a little off. NO change
I had just the input gear in the housing, and was spinning and noticed the gear was wobbling??? So i then put the short shaft that the lathe and spun it to see if it was true.... Straight as an arrow. I the put the input gear on it and wobble came back. Long and short of it is in our case the input gear is out of round. Had another from an extra tough box mini so checked it and put it all together and all is well
